Old 09-25-2003, 04:10 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
Cluth Fan
I have the stock clutch fan on my 89 gt and its on all the ime i thought it was supposed to go on and off by its self? I took it off a while ago to change my water pump maybee i installed it the wrong way?
Old 09-25-2003, 05:44 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Cluth Fan
Well, your fan clutch doesn't just turn on and off. Since it is belt driven by the serpentine belt, it will always be spinning as long as your motor is running. The concept behind a clutch fan is to use up less hp at higher rpms. At an idle the fluid inside keeps the clutch tight so it turns the fan faster, so you motor doesn't over heat. At higher rpms the fluid inside moves outward, creating the clutch to spin more freely, spinning the fan less, for less drag on the motor.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-25-2003, 10:37 PM
that explains alot but when i rev the engine you hear the fan whinning as it spins like you can hear the blade fighting through the air,it spins fast even at high rpm's?
Old 09-26-2003, 03:35 PM
FastFords1923_99 FastFords1923_99 is offline
Thumbs up fan Huh!
1) Dude have someone you trust sit inside the car with the keys
2) parking brake on
3) look at the front of the motor
4) dont stick your head inside or other body parts
5) have pal bump the key on off quick
6) memorize which way the motor turns and look at the fan blades they are supposed to pull air thru the radiator
good luck
Quote: Never hotrod your daily driver, it just is not comfortable. (in the dragster)
Old 09-26-2003, 03:47 PM
HiFlow5 0's Avatar
Stanger
Re: Cluth Fan
Yes, the fan will still spin pretty fast even at high rpms, since there is still centrifugal motion coming from the motor. There is still a looseness though, compared to if the fan was bolted directly to the water pump. That whooshing sound you hear is the fan cutting though the air, which is normal.
-2013 Ford Flex
-1999 Ford F150
Old 09-26-2003, 05:02 PM
well that noise sucks its louder than everything else im gona go with a new electric fan I know they sell like performance fans do the cut the wind drag down or give you any hp?i know if you loose the stock fan and go with electic it gives you like 15 hp. this is a really stupid question but if i take the fan of and have no fan it will over heat correct?
Old 09-26-2003, 05:20 PM
[SS]Disabled's Avatar
[SS]Disabled [SS]Disabled is offline
Re: Cluth Fan
If it wouldnt overheat w/out a fan then there wouldnt be ne, right?
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
96 olds cutlass 3.1 fan relay AK47 SRH420 Cutlass Series 1 04-16-2009 09:33 PM
06 Expl Heater Fan stuck full blast/can't stop! Kirkwwhite Explorer | Explorer Sport Trac 3 04-02-2009 09:17 PM
Envoy Fan WesPomp Envoy 3 03-31-2009 03:28 PM
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
