Old 09-24-2003, 04:33 PM
4thGen4Door's Avatar
4thGen4Door 4thGen4Door is offline
Proportioning Valve CRX 40/40?????
Following my rear disk break swap I changed the master cylinder to the 15/16" EX form my stock 13/15" DX. I still have the DX booster. but I need to change my Proportioning Valve to one for a 4-disk setup, It has "4040" stamped on it. compared to the 2disk2drum one that has "3030" on it. Can someone look at there 90-91 CRX si w/rear disks and see if you Proportioning Valve has "4040" stamped on it? and some on that has a EX 4 door what are the number on you P Valve? Thanks.
I dont thing I can use the Integra one cuze not all the bolts line up.
Integra Valve
Old 09-24-2003, 04:41 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I used the interga one on my swap.
Old 09-24-2003, 06:25 PM
Re: Proportioning Valve CRX 40/40?????
What MasterCylinder and Break booster did you use? What you integ P valve did you use?
Old 09-25-2003, 02:02 PM
kris's Avatar
Re: Re: Proportioning Valve CRX 40/40?????
Everything was from a 91' Integra.
Old 09-25-2003, 03:00 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
yeah, that pic you posted is 94+ body style, which wont work. the 90-93 will work though.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
