Old 09-24-2003, 12:29 PM
snipez's Avatar
snipez snipez is offline
rotten egg smell
hi
i have new wires, new plugs, new alternator
would a smell of rotten eggs be coil related?
the car takes a second longer to start when cold
Old 09-24-2003, 02:11 PM
Import_fantasy's Avatar
Import_fantasy Import_fantasy is offline
this is not a good sign, u could have some serious problems with your engine internals, i would get this checked out by a mechanic ASAP
Old 09-24-2003, 02:39 PM
funkdaflex1 funkdaflex1 is offline
Some clutches smell like rotten eggs when u burn them. So if your riding your clutch that could be it.
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 09-24-2003, 03:41 PM
snipez's Avatar
Re: rotten egg smell
its an automatic,
just had a tranny flush
Old 09-24-2003, 05:11 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
sometimes bad cats will make the exhause smell like that
Old 09-26-2003, 12:46 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
well first i'd try a shower j/k but could be cat conveter do you have an aftermarket one or a strait pipe? might be something in the motor too.
Old 09-26-2003, 02:24 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
For something to smell other than its original form there has to be a catalyst, and in most cases its heat. So, lets start analyzing what it could be. Fluids, rotating metal, and the exaust. Since you just had the tranny flushed, Id check that first. Some mechanics can't even put the oil plug back in good after its changed, let alone do anything with something "more complicated" like a tranny. What i'd do is check all the fluid levels and mark them off, to make sure I wasn't burning or loosing anything. BTW: when does it smell? Like does it go away if it sits for a while with the windows down?
What do you mean by the car takes longer to start when its cold? You mean longer than it normally would? Usually unless something that frozen or drained the car should only take a few compression strokes to start (assuming you haven't done alot of work to it). I'd go with ace's suggestion too, check everything thats not stock, first.
I know for a fact that burning clutches (or plates, whatever) stank pretty bad, so if your tranny is about to go, it could be a sign.
HTH
Buzz1167
Old 09-26-2003, 03:23 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
I had no catalytic converter last summer and with the windows down on a hot day it was pretty rank... check your exhaust.
Old 09-27-2003, 04:10 PM
snipez's Avatar
It just cranks about a second longer when cold. If I have been driving around for awhile, then turn it off, it starts up no problem. And another problem is the engine is super loud when cold. All the power is there, its just a loud whurrrrrrrrrrrrrrrrrrrrrrrr.
My whole tranny and engine is under warranty, how can I fuck it up and make it look like an accident? lol
Old 09-29-2003, 08:47 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Usually a Honda that takes a little longer to start, after setting for awhile can be caused by:
1. Leaking injector
2. Fuel pump - there is a check valve in there to maintain pressure after shut down.
3. Fuel pressure regulator - it's failing causing the pressure to bleed off.
4 Plugs & wires - which you have akready re-placed...
As far as the rotton egg smell, most of the time that can be realated to running a little to rich. Might have the fuel pressure checked, this could also be causing the above mentioned...
Just some thoughts...
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 09-29-2003, 11:33 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
its your cat convertor bro, it happens all the time. any car also takes longer to start when its cold also, that isnt a problem.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-30-2003, 01:56 PM
I would like to recite a passage that I fould while looking for engine overhaul info, I think it will help...
its from the Chilton honda crv manual...
"8. vehicle has a rotten egg odor when driven
a. check for a leaking intake gasket or vacum leak causing a lean running condition. A lean mixture may result in increased exaust temperatures, cauing the catalytic converter to run hotter than normal...
b. Check the vehicles alternator and battery condition. If the alternator is overchanrging, the battery electrolyte can be boiled from the battery, and the battery casing may begin to crack, swell or buldge... if this occurs, neutralize the area with baking soda and water solution and replace."
HTH
Buzz1167
Jon N
Old 09-30-2003, 02:02 PM
Ricochet's Avatar
Banned
yikes... doesn't sound good
Old 09-30-2003, 02:46 PM
Ok, I think ive got your problem solved. Intake and exaust, thats about all it could be. The manual said look for intak problems causing a lean condition. I know for a fact when the intake is loose or off, it is loud, I also know that when you run a 2stroke engine lean (i havent run a 4 stroke lean before) that the exuast is REALLY loud (of course im talking lean enough to kill it). So based off of this, I would suggest taking off the intake manifold and replacing the gasket, along with the throttle body, of course thats what I would do, youll probably have to justify it for yourself (becuase I have no idea how much that would be), but I would defintely check all the bolts on the intake against the torque specs in a manual, or make sure one isnt missing or something like that. A loose exaust can also cause a lean condition, but thats usually fixed with the FI system, so that wouldn't be my best guess.
HTH
Buzz1167
Jon N
Old 10-02-2003, 09:26 AM
A vacuum leak on a Honda will not cause a "lean" condition in a properly running engine. It will just give you a uncontrolable idle, at least on a 4 cylinder. However if you have other things going on, could make a differance. In fact it's really hard to make a Honda run lean when troubleshooting. Usually you will have to dis-connect a injector, before you will really see a change from the output of the O2 sensor. Even then the ECU will just give the other injectors more fuel...
Honda's use a "Speed/Density" system for management, which is very different from the rest of the automotive world. Meaning, anytime the MAP sensor sees more air in the intake from a leak. It will tell the ECU to make the injector pulse width a little longer. To compensate for the added air, causing the idle to speed-up rather then going lean. Thats why you can add a CAI, and not worry about the engine running lean from moving more air. Otherwise, we would have to being playing with the fuel pressure, or injector pulse width with external sources. The MAP/PA sensors are doing it for us automatically in most cases. Here again on a properly maintained engine...
Have you pulled the plugs and checked their color...?
I never have ran across anything about how a v6 is managed tho. Soooo, that may be a little different story. hehehe
ZYDNE SECU, 450's
car dead rotten egg smell, strange noise yall Intrigue 11 04-28-2010 07:11 PM
rotten egg smell sunfirechick General Discussions 16 11-27-2004 03:27 AM
Auto tranny Q's; rotten egg smell 86FieroGT Engineering/ Technical 3 05-10-2004 12:41 AM
Rotten egg smell......... daddymart001 Grand AM 1 12-04-2003 08:09 PM
