Old 09-23-2003, 09:56 PM
ex-r's Avatar
ex-r ex-r is offline
Alclad question
I tried a search, but found nothing. I was wondering for the Alclad chrome, you have to use a black enamel base. My question is, does the black base have to be fully cured before I can spray the Alclad? I just sprayed to base this morning, and I was wondering if I can spray the chrome on tomorrow morning. Anyone who used the chrome before please let me know. I am anxious to spray it. Thanks.
Old 09-23-2003, 10:02 PM
khart khart is offline
Send a message via Yahoo to khart
I usually shoot the chrome once the enamel base is tacky-dry, but letting it dry longer shouldn't be a problem ... in fact, I've heard that it helps to go over the black base with a polishing cloth before shooting the chrome.
Old 09-23-2003, 10:32 PM
Sigmaman's Avatar
Sigmaman Sigmaman is offline
AF Premium User
Send a message via MSN to Sigmaman
khart is right,if you let it cure and then give it a buff with a soft cloth,it will give a better result.
www.sigmamansmodels.com
Old 09-23-2003, 10:52 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
make sure the black is very dry is my advice, I didn't wait long enough once, it never cured right. I now use Duplicolor for the base because it dries fast, also if you put a coat of clear over the black it will have more depth to the shine
Old 09-23-2003, 10:56 PM
Okiemodelbuilder Okiemodelbuilder is offline
Here's how I do it. First I airbrush Testors Boyds gloss black thinned 50:50 with Model Master airbrush thinner with my Aztek airbrush. After 2 to 3 coats of black I clean the airbrush and let the black flash over. Then I shoot 2 to 3 light mist coats of Alclad at 15psi.
After all of this I bake in the dehydrator for 6-8 hours. I got a hint on the HHMB about using Humbrol gloss black because it dries better than Testors. I'm gonna test Humbrol with my next Alclad shoot.
Old 09-23-2003, 11:28 PM
ZoomZoomMX-5's Avatar
I've sprayed Alclad Chrome over cured Tamiya spray black and freshly applied Model Master black enamel. It didn't adhere to the Tamiya paint, looked good but you couldn't touch it.
It adhered perfectly to the freshly applied enamel. Of course buffing the black would give an even better, cleaner surface...but I haven't tried it. Testors enamels never dry very hard, so the Alclad should adhere to it...it needs to bite into the surface a bit so it won't come off from handling like it does w/lacquers. Since it's applied in microscopically thin layers, it shouldn't hurt the enamel at all.
Has anyone tried it over dark blue, gray, or white? I found the chrome effect slightly dark over black, and think that gloss white enamel may brighten it up a bit.
My Fotki Album
Old 09-24-2003, 01:02 PM
ex-r's Avatar
Thanks everyone. I sprayed it this morning and it came out alright. The finish looks a little hazy though. I think I sprayed it on too thick. Actually too many layers. Live and learn. Hopefully the next time I use it, it comes out better.
Old 09-25-2003, 01:52 PM
dag65's Avatar
Re: Alclad question
If you spray over white it won't show up chrome at all, Alclad actually works like a miror and relies on the dark backgroud for the refelctive quality. Much like the chameleon paints
Old 09-25-2003, 05:09 PM
Murray Kish Murray Kish is offline
Getting Old...
dag65,
No offence, but have you tried putting the Alclad over white?? I haven't either, but I know that you could do it with the SNJ Metalizers. I used to use their aluminum buffing powder on white and it turned out pretty bright.
Like I said, I don't know for sure if it will work either, but it would be good to know. Unfortunately my bench is still not set-up (likely another month or two away) so I can't really try it...
Murray
Old 09-25-2003, 05:13 PM
dag65's Avatar
Re: Alclad question
Originally Posted by Murray Kish
dag65,
Murray
Yes and it does not work, the metallizers are totally different than Alclad, over a very dark blue or something you might get some fair results but Alclad relies on the black background for refelctivity
Old 09-26-2003, 11:14 AM
Getting Old...
Thanks for clarification on that dag65. Good to know...
Murray
Old 09-26-2003, 09:16 PM
Sebstar's Avatar
Sebstar Sebstar is offline
has anyone ever tried using one of those chrome silver pens?? Can't remember what they are used for commercially, but I can remember having some around the house a long time ago...
Old 09-27-2003, 06:07 PM
Tommy Gunner's Avatar
Tommy Gunner Tommy Gunner is offline
Re: Alclad question
I have a Sanford Silver marker and a Sanford Gold marker they both are fine tipped and are almost as good as Dupli-Color paints and its recomended you use it on a black surface.
http://photobucket.com/albums/v107/MacsModels/ Pictures of my models
Old 09-27-2003, 09:37 PM
Sebstar's Avatar
thanks for that info. would probably be a lot cheaper and easier to do
Old 10-06-2003, 04:07 AM
Inquisitor Inquisitor is offline
Strange, I'm using the Alclad Black Base for the Chrome as suggested by Alclad, but it still comes off. Should I switch to some Black Enamel or spray the Chrome while the base is tacky?
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
alclad polishing kit question wouter1981 Car Modeling 0 03-11-2006 11:25 AM
Question about Alclad Chrome Verminator Car Modeling 1 04-02-2004 03:08 PM
