Old 12-04-2001, 11:14 AM
LynxMS LynxMS is offline
Send a message via AIM to LynxMS
Question About High Mileage
What actually happens to your engine when you have a high mileage car? Does it get old and wear down?
Thanks
Dont waste tomorrow, Reaching for yesterday, Start with today.
Old 12-04-2001, 11:24 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Depends on the maintenance of the engine. As some cars get to the point where the engine can no longer perform, it dies. But I've seen plenty of high mileage cars and they run like the same day they were purchased. The key to a good running engine is maintaining a strict schedule of proper maintenance at the time of service. For higher mileage engines, like mine at 139,000, I make sure the oil, fuel filter and other things like timing belts, etc. are in good working order.
Not sure if I answered your question, but I think you get the idea.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 12-04-2001, 11:29 AM
Yeah...
Yea i get it but i was thinking is there a such thing as a deadline? Like you maintaining till it cannot perform at all.
Old 12-04-2001, 11:35 AM
enginerd's Avatar
enginerd enginerd is offline
Many parts do in fact become worn in a high-mileage engine. First you've seen old cars which blow smoke when started after sitting for a period of time. This is caused by worn valve stems. Second are worn piston rings. These cause a lack of compression which lowers power. These two symptoms are the most common. In case of Diesels, one must be very vigilant about checking the oil, as old diesels will suck it up and burn it soon causing the engine to self-destruct from lack of oil. Don't be scared off from a high mileage engine, I've seen engines with over 400,000 miles on them running strong!
Old 12-04-2001, 11:39 AM
DVSNCYNIKL's Avatar
R.I.P. DAD 3/25/11
Re: Yeah...
As enginerd explained, you have parts that over time become so worn that they fail. But this can be said about anything that has moving parts. Usually you hear of car blowing a lot of smoke out the exhaust, a car burning oil, failures here and there. All signs that parts are worn out. Which is why I said that with maintenance, the likelihood of this happening is minimal since you always keep things new. Some people rebuild their engines. Others do swaps and such. Depends on what floats your boat.
Old 12-04-2001, 11:49 AM
enginerd's Avatar
In the case of what I mentioned, you could drive the car for quite some time before the engine completely "gave up the ghost". Most engines really don't completely wear out, often something really expensive breaks and a new engine is cheaper than repairing the old one.
Old 12-04-2001, 12:16 PM
Got it.
Thanks now im sure how high mileage works!
Old 12-08-2001, 12:56 AM
JBL85 JBL85 is offline
Send a message via AIM to JBL85
usually after around 150k you will lose compression/power
if its mainly high freeway miles its not as bad...car can handle it a little better, but its still wear and tear and that will always bring a car to its knees
High mileage ATF for high mileage auto?? Ramblin Fever Rodeo | Passport | MU 31 07-14-2006 04:58 PM
worried about high mileage eddie98 C/K 2 11-26-2003 05:26 PM
high mileage a problem? ImportNut1212 Integra 6 03-08-2002 01:24 PM
