Old 09-23-2003, 06:44 AM
mtdxx mtdxx is offline
can i get codes from my civic?
I have 94 civic DX. Is there a way to retrieve diagnostic codes from the car? I know on some GMs you somehow jump places on the connector under the dash to get the dash to flash them, is there a way to do that with my civic?
Old 09-23-2003, 11:08 PM
dan91SE dan91SE is offline
There is a blue connector hanging loose, or tucked away,just above your ECU. (ECU is located on the right of the pasenger's footwell). If you jump the wire when the check engine light is on, the check engine light should start flashing your trouble code. Never got a check engine light so far so I did not test this but it should work since this is the same connector that needs to be jumped when adjusting the timing.
Old 09-24-2003, 10:22 PM
never had my check engine light come on either. That is interesting to know where the ECU is though, I will be looking for it and that connector, It'll be good to know in the future.
Old 09-25-2003, 12:42 PM
jameskersten jameskersten is offline
Re: can i get codes from my civic?
i not sure if i read that right but your ecu is under the dash by your passenger side's foot.
1993 honda civic si -turbo charged b18c1
dynoed: 316whp at 11lbs
Old 09-25-2003, 04:59 PM
Well I do not know if I'm reading your reply correctly either. The ECU is not under the carpet like in the 4th gen; it is on the side (the right side as you look from the seat).
Go here and get yourself the repair manual :
Helms Manuals
I strongly recommend buying the hard copy unless you want grease and such all over your laptop. www.helminc.com The Manual is worth every penny if you like working on your car .
can get parts from japan fierojapan General Discussion 24 10-30-2005 08:48 PM
Cant Get Code From 2000 CD Head Unit Sammysurfer Montana/Montana SV6 5 01-29-2005 11:32 PM
How do I get codes from computer in 87 Pickup? atmman C/K 4 09-18-2004 08:25 AM
I heard you can get R34's from Cali for about $40 kp4sho General Discussion 1 10-07-2002 03:06 PM
you can get one from the salvage yard that is running for that price defuse411 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 05-08-2002 05:56 PM
