Old 09-22-2003, 09:39 PM
baruba baruba is offline
Unhappy B18a clutch release problems
Before dropping the motor I installed a act flywheel, clutch and pressure plate.
As soon as I bolted the tranny and motor together i checked the release arm to see how stiff it will be... it seemed to be very easy to move.
I compared to the zctranny I pulled out and they were similar so I figure everything is OK.
But now when I press the pedal it just plops down to the floor with very little effort, this is a extreme pressure plate so it should pretty damn stiff.
I have no idea what is going on please help.
Old 09-23-2003, 10:27 AM
CRXtc CRXtc is offline
Banned
Re: B18a clutch release problems
is your clutch cable properly connected?
Old 09-24-2003, 12:40 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
u gotta adjust it more. k you konw how theres free play and when u lift it up its easy then all of a sudden its gets hard, right there thats your clutch engaging, so adjust the cable till theres hardly any slack to where the lever gets tough to move. then try push it in, should be good
Team Lonely Drivers
Old 09-24-2003, 12:49 AM
Booya
YES CIVICKILLER
Damn im such a newb , so went to see if i could figure it oout i pull up it goes with little effort then stops... then i give it anice hard tug and THEN i feel it disengage the clutch, sorry for wasting anyones time and thanks for trying to help
civickiller U SO SMART!
oh btw teh new clutch setup feels real nice and STIFF!
Old 09-24-2003, 12:54 AM
thank you thank you (blows kisses to crowd) thank you
Team Lonely Drivers
Clutch Release 1988 F-150 Redline 9000 F Series 1 11-15-2004 09:01 AM
Clutch Release bearing classicstangracer Wrangler 1 11-10-2004 09:41 AM
Clutch release Engine Noise sherid Wrangler 2 08-05-2004 07:06 AM
Clutch Release bearing ltrapp2589 Jetta/Vento/Bora 1 02-25-2004 06:04 PM
popping after clutch release. praxis Engineering/ Technical 5 01-23-2002 07:44 PM
