Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-22-2003, 10:28 AM
meb1130 meb1130 is offline
97 Explorer - Check Engine P0153 code
Check engine light came on & had it read at Autozone. The P0153 code indicates O2 Sensor CKT slow response, bank 2, sensor 1. Also getting a Manufacturer Code 1151, Fuel/Air Metering, lack of HO2/S21 switch, sensor indicates lean. Was told most likely an O2 sensor needs to be replaced. Was told there are 4 sensors, 1 before & 1 after each of the catalytic converters. Where is bank 2, sensor 1 & is this pointing at 1 of these 4 sensors?
Old 03-17-2004, 08:03 AM
ejburke1 ejburke1 is offline
Send a message via AIM to ejburke1
Re: 97 Explorer - Check Engine P0153 code
I have same problem on same year Explorer. Did you ever find which sensor is bank 2 sensor 1? Did you replace it yourself? If yes, any words of widom to share?
Thanks
Old 03-17-2004, 04:42 PM
Opera House Opera House is offline
Bank #1 is always the same side as spark plug #1, the passenger side. Sensor #1 is the engine side, Sensor #2 is after the cat. A box end wrench will fit over the connector if you break off the locking tab. If it really is bad, no reason not to cut the wire. An open end wrench will just strip. Some auto part stores have the socket on loan a tool. It will take a good hit of a hammer on a wrench to get it off.
Old 03-18-2004, 06:48 AM
P0153 code
Thanks for the update.
Does the new sensor have to be torqued or just hand tightened?
