Old 09-22-2003, 02:21 AM
crabby760 crabby760 is offline
ls header fit b16a?
i need to know this my friend has a 97 ls motor in his del sol and he has a 4-1 dc header will it fit my jdm 95 b16a motor??? if so let me know asap cas he's selling it to me for 50 bux.... late
Old 09-22-2003, 02:30 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
I don't think it will, but buy it anyway and if it doesn't fit sell it on eBay for $200 and put that money toward one that does fit.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 09-22-2003, 02:34 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
no it wont !
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-22-2003, 11:39 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
It will bolt up, but it is a little bit taller, if your car is lowered a lot, it may cause a clearance issue.
Old 09-22-2003, 03:04 PM
so will it fit or will it not fit... 2 different answer's my car is lowered but not all low... so if it fits ill get it if it wont bolt on i wont get it.... and are they o2 sensors in the same spot? i need to know all this
Old 09-22-2003, 09:51 PM
HondaSi88 HondaSi88 is offline
i bought a ls header and it didn't fit on my b16........i guess yours might be different
Old 09-25-2003, 05:50 PM
does anyone know for sure if i buy a dc 4-1 header from a ls engine if it will bolt on my b16a i need to know 50 bux is a great deal... someone has to know for sure.... LET ME KNOW THANKS!!!!!!
Old 09-25-2003, 05:52 PM
Just buy it and if it doesn't fit, then sell it, you can get 150-200 for it easy.
Old 09-25-2003, 06:06 PM
but i wanna know if it will fit someone has to know if the header will bolt up to my b16a ???
Old 09-27-2003, 02:02 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
YES, the header will fit and bolt onto the head. The problem lies at the flange where it bolts to the cat. You'd need either a Teg cat or test pipe.
Old 09-27-2003, 05:18 AM
hey who can i beilieve??? somepeople saying NO FOR SURe some saying maybe and u said yes it will... i was planning to weld it to my cat... let mek now
Old 09-27-2003, 11:55 PM
B16EJ1's Avatar
B series head bolt patterns are the same. VTEC and non-VTEC alike. I have a JDM 98 Spec ITR header and bought the JDM cat because the patterns at that end are different. Just try to install and you'll see what I mean. Sh*t, it's only 50 bucks.
Old 09-28-2003, 02:40 AM
i need to know 100% for sure that it will bolt to the block the cat part isnt a problem i can just weld that together but it needs to bolt up to the head with no problems people let me know... THANKS
Old 09-28-2003, 11:06 AM
Re: ls header fit b16a?
Look dude, the intake manifold bolt patterns are different between the GSR's and PR3 heads (B16A/CTR, ITR), The exhaust manifold bolt pattern is the same. The flange at the cat, and the height are the difference's.
Old 09-28-2003, 12:53 PM
ok so for sure now the dc header from my friends ls engine will bolt up to the "HEAD" fine only problem will be the cat lining up if that is the case then its fine im going to weld the header to the cat anyhow...
