Old 09-21-2003, 08:05 PM
TURBOSATURN's Avatar
TURBOSATURN TURBOSATURN is offline
zc head
i ran into a guy the other day who said he had a zc dohc head that would bolt right up to my stock d16a6, is this true? he said $100.00 bucks for it, does this sound like a good deal and what kind of gains am i looking at?
Old 09-21-2003, 08:10 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
Even though both engines are d series you can not bolt a dohc head to a sohc block. If you want to get more power by puting a new head on your a6, you can throw on a sohc vtec head from a y8 or z6.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 09-21-2003, 08:13 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
yeah that guy is totaly just tryin to make a bill off u...tell him to suck my left nut!
so whats wrong with a d15b2 again?
Old 09-21-2003, 09:03 PM
i dont want to go vtec because im going turbo. if i could find a soch zc head would that be better.
Old 09-21-2003, 09:04 PM
yeah the sohc non vtec zc head would be a little better. I have heard it is rated at 118 hp compared tot he a6 at 108 so that is better. why don't you just stick with the a6 and build it? Also why wouldn't you want vtec for turbo?
1989 Crx Si
-thermal cat back
-Hx wheels
Old 09-21-2003, 09:19 PM
dirty91crx's Avatar
yeah the sohc non vtec zc head would be a little better. I have heard it is rated at 188 hp compared tot he a6 at 108 so that is better. why don't you just stick with the a6 and build it? Also why wouldn't you want vtec for turbo?
188hp u sure.....hehehehe if it were 188 hp everyone would be getting that over the b16....anyways as far as vtec turbo...its a lil harder to tune with vtec rahter than non.
Old 09-21-2003, 09:30 PM
Re: zc head
Yeah my bad I meant 118...I hit the wrong button. I will change it right now for u.
1989 Crx Si
-thermal cat back
-Hx wheels
Old 09-21-2003, 10:19 PM
after you guys told me that i called the guy and he claims he didnt say that but i asked him about the zc sohc head and he said $75 for that does that sound reasonable and would there be a decent increase in power or would it even be worth it. also in the long run is this gonna good or bad if i go turbo?
Old 09-21-2003, 10:30 PM
dirty91crx's Avatar
not a bad price if its got low miles....i can get z6 heads here for $75 a peice if i pull it and no more than 90k on them....
Old 09-22-2003, 12:57 AM
so would this be a smart buy or a waste of my money?
Old 09-22-2003, 01:05 AM
dirty91crx's Avatar
well the zc sohc has a slightly larger cam than the a6...also you would be able to work the head...ive seen 13hp gains on mild p&p on the a6 heads....id get it if it were jdm zc head...
Old 09-22-2003, 02:15 AM
91civicDXdude's Avatar
VTEC isnt necessarily harder to tune, especially with the sohc vtec + turbo. all you do is activate VTEC before the turbo spools so you basically just use it for the bigger cam.
Although VTEC is a high lift/high duration cam, as opposed to a high lift/low duration cam like a true turbo cam, the extra valve lift offered by VTEC will give you more power with a turbo than with a non vtec sohc head.
thanks for your help man. also just incase i can get ahold of one is the jdm zc intake manifold any better?
