Old 09-21-2003, 06:32 PM
lexicon_1 lexicon_1 is offline
Send a message via AIM to lexicon_1
Crx 88 reciever installation
This should be so easy! God why is so hard? because i have no idea what wires do what. I found the start up wire(amp kit) its a solid black one, but the rest are all multi colored and not labled. I've replaced 4 other stereos and the wires have all had some identifier markings on them. Why not these? HELP!
I need a wiring diagram or schematic that will tell me wich wires go where. oh and uh, i need some new fuses, but the honda dealer doenst carry them, they're fuse 30 and im having a hell of a time finding them. Help is appreciated.
Old 09-21-2003, 07:49 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
If you are talking about radio/stereo wires go to http://www.automotiveforums.com/vbulletin/t118785.html an it is post #12. You should be able to find fuses at an auto parts store.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 09-29-2003, 11:30 AM
Re: Crx 88 reciever installation
Thanks for the layout. The thing is, now I have all the connections i.e. the new harness, the stripped out old one and everything put together, but i end up with this weird wire left called an illumination wire. I'm getting no power to the new headunit i bought and I think this might be the problem but im not sure.
I have the ground, main, switched and power up sources routed to the old wires from crx, but i still ant get power. I checked and rechecked the connection chart from the12volt.com and havnt been able to find the problem. Could someone help me?
Old 09-29-2003, 11:36 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id recheck your wires, the illumation wire is for cars that have dimmable radios, crx's dont have it. sounds like you switched your ground and power wires around. id unplug everything, make sure the deck turns on then start wiring in for the speakers.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-29-2003, 11:39 AM
T-Mo's Avatar
Re: Re: Crx 88 reciever installation
You almost never have to use the illumination. I would say recheck the wires. The main 4 (power, ground, remote, memory) In which on the new harness would be red, black, yellow, and blue. The rest of the wires are speaker wires. Check your fuses also.
'93 Honda Civic EJ2
