Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-21-2003, 12:33 PM
syk_pal_jgomez syk_pal_jgomez is offline
Send a message via MSN to syk_pal_jgomez
Turbo on a B20
If i had a b20 swamp into my 2000 honda civic. will a turbo still fit.
Old 09-21-2003, 01:22 PM
boosted331 boosted331 is offline
It's the same size as all other B-series (save for B16's which have shorter deck height) so yes it will fit with a turbo. B18B would be a better choice due to thicker sleeves if you're going turbo though.
Old 09-21-2003, 05:48 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
I agree 100% with boosted331 the B18B would be a better choice because the cylinder walls are too thin on a B20 for turbo. The B20 is the exact same motor as the B18B except it has a bigger bore. Everything else is exactly the same.
Old 09-22-2003, 09:54 PM
HEVY_HITTER HEVY_HITTER is offline
Send a message via ICQ to HEVY_HITTER Send a message via AIM to HEVY_HITTER
why is the b18 better than the b20 for turbo........ive heard several different opinions on this and was wondering if b20 turbo would be as good or better than turbo b18 if something such as block guard was used......or if i closed the deck......what yall think???? any suggestions????????
thanks fellas
GAS
Old 09-23-2003, 05:43 PM
Re: Turbo on a B20
thanks fellas
GAS
B18 will, more than likely, last you longer than a B20 for a turbo setup. You can use a block guard which reinforces the sleeves, but that doesn't change the fact that they're thin and weak. Closing the deck = sleeving, and at that point it doesn't matter if you get a B18 or a B20. If you're gonna sleeve it right off the bat get whatever block is cheaper for you at the time.
Old 09-26-2003, 09:54 PM
but which would be better???? would the b20 still have more torque than the b18c1?????this is for turbo application......
thanks
GAS
Old 09-26-2003, 10:17 PM
whtteg's Avatar
Who said anything about a B18C1? If you go turbo how much boost are you looking to run? And how much HP? Than we can give better advice based on that.
Old 09-27-2003, 10:18 PM
i was wanting to run a built (pistons, rods, etc....) b20/vtec with drag 3 turbo with the t3/t4 turbo on 12 psi daily and maybe 18-20+ for track use. i was wanting somewhere in the 280-350 range for hp. also, what would be better for this b20/vtec, b20 without vtec head, or any other suggestions on engine that should be used?
thanks
GAS
Old 09-27-2003, 10:28 PM
Re: Turbo on a B20
thanks
GAS
If you are going to sleeve it, get whatever is cheapest for you, but a B18C5 block would be nice for squirters and slightly shorter stroke than LS/B20. If you don't plan on sleeving don't run a B20 because the sleeves will crack on you.
Old 09-27-2003, 11:56 PM
billab2ong billab2ong is offline
you obviously dont know how much 12 or 18-20 psi is...so i shouldnt even help you but im going to....
1st of all...LS/Vtec=best turbo...but i dont like them b/c ls/vtec is just one more variable into the equation that isnt necessary. i would suggest sticking to a B18b1 block. get JE 9.1 pistons and cower rods. you should be good to about 15 psi on 93 octane gas or maybe 16.5 psi on race gas. to get in the 20 psi range you are going to probably need to sleeve your engine. unless you dont mind blowing your engine up...then i suggest running 18-20 psi on an unsleeved B18B1...just plan on replacing the motor... i dont know how much money you have...but if you dont have crazy money to spend....i would stick to an b18b w/ je 9.1 pistons and cower rods. then you can run 12 psi daily and 15-16psi at the track...i personally wouldnt go any higher then 18 psi but i would also have it tuned at both 12 psi and 18 psi on hondata and just swap the chip when i wanted to go to the track.....thats my 2 cents...if you dont like it...go fuck yourself b/c you dont have a clue what is involved in turboing a car up to 20psi.
Peter Gibbons: I don't like my job and I don't think I'll go anymore.
Joanna: You're just not gonna go?
Peter Gibbons: Yeah.
Joanna: Won't you get fired?
Peter Gibbons: I don't know. But I really don't like it and, uh, I'm not gonna go.
Joanna: So you're gonna quit?
Peter Gibbons: Uh-uh. Not really. I'm just gonna stop going.
Joanna: When did you decide all that?
Peter Gibbons: About an hour ago.
Joanna: So you're going to get another job?
Peter Gibbons: I don't think I'll like another job.
Joanna: Well what are you going to do about money? Bills?
Peter Gibbons: You know I never really liked paying bills, I don't think I'm going to do that either
Old 09-28-2003, 08:47 PM
Re: Turbo on a B20
Originally Posted by billab2ong
you obviously dont know how much 12 or 18-20 psi is...so i shouldnt even help you but im going to....thats my 2 cents...if you dont like it...go fuck yourself b/c you dont have a clue what is involved in turboing a car up to 20psi.
well dont answer me then if you think you shouldnt.....
why dont you get off my dick and stop gettin so offensive? if your gonna attack me let me atleast give you probable cause bitch. i came here to learn about cars and engines and shit. i didnt come to have a dumbass like you who thinks they know everything jump on me. i admit that i dont know much about engines....ok. but thats why i came here. so give me a chance to learn because not everybody was born with the infinite wisdom of engines like you evidently were......anybody else wanna answer my question without verbally attacking me????
Old 09-28-2003, 10:23 PM
sideshowrich's Avatar
sideshowrich sideshowrich is offline
2 people short of a 3way
Send a message via AIM to sideshowrich Send a message via MSN to sideshowrich
Re: Re: Turbo on a B20
What about the new Dart blocks? These look like great platforms to build on. Honda Tuning built a turbo B18 on one of these blocks and got over 500 HP out of it. I don't know what grade fuel they were running, but that ain't bad. Also I think I read that the blocks have the oil squirters. A bit expensive, but worth it if you're gonna crank the boost up.
Old 09-29-2003, 09:38 AM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
no most of us would rather not help u now, cause afterall u come on here and disrespect us and he said it wasnt worth his time trying to explain something to u through posts, it would be easier to just search on here to find answers like that, and u came back and verbally attacked him. so if u want help u gotta respect the people that have been here, cause u have already lost a lot of respect now, and u will be lucky if u get much more help from this site, because many people that are on here frequently like myself are not gonna help u because of something like this.
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Old 09-29-2003, 03:01 PM
Re: Re: Re: Turbo on a B20
whats up with this???? i searched many times before and found helpful info. but none about the exact terms of what i wanted to do. i cant beleive that its all being blamed on me now. i come on and ask a simple question to LEARN about something and then he comes along making it out like he's doing me a huge favor by even responding to the post. if he doesnt want to fool with newbie questions maybe all the veterans of this site should ban all newbies because thats what newbies do, they ask ?'s that dont seem too relevant. damn esp i always thought you were a nice guy by all your posts but i guess i was wrong , when just because im new i get flamed, criticized, and mistreated when asking a simple question.
Old 09-29-2003, 03:08 PM
Re: Turbo on a B20
if you dont like it...go fuck yourself .
and i attacked him??? why should i respect him so much when he has no reason to say this but he does. i never even talked to the guy before and he says this like ive been arguing with him and stuff. whats up with that billab2ong??? can we settle this?
Turbo B20 ImportBuilder N2O | Turbo | Superchargers 1 05-09-2006 02:18 PM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi JDM Motor & Parts info/chat 8 01-21-2006 01:11 AM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi N2O | Turbo | Superchargers 5 01-08-2006 10:40 PM
Project street TERROR 2: RWD, Turbo B20 powered CIVIC Mean_B16 WIP - Street 12 11-27-2004 11:01 AM
how about a non vtec turbo b20? edman24 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-15-2003 04:17 PM
