Old 09-21-2003, 05:23 AM
team_e-brake team_e-brake is offline
Exclamation Need More Speed!!!!!!!!!!!
how do i make my 96 accord non v-tec go over 112 i think it's the govorner but i dont know where it's located. can someone tell me where it's located and how to take it out. i really need to take my car up to higher speeds i have expensive Z-RATED tires help me and one more thing if i remove the govorner what will my top speed be and will it mess up my car???????
Old 09-21-2003, 01:41 PM
JDMAccordLX JDMAccordLX is offline
Well, I have a 96 Accord LX myself. The short answer is you're stuck with the gouvener. It actually stops you at 115 although I'm sure if varies somewhat. However, there is a way to chip your ECU into ignoring the gouvener, I'm not quite sure how to do it but it involves cracking open your ECU and soldering a resistor in there. Do a search, I'm sure you can find a wiring diagram somewhere that explains it in more detail. I'm not sure what the risks are in bypassing your gouvener, might want to research that a bit before you try anything.
Best 1/4 time:
17.130 @ 81.30mph
60ft. 2.557 w/a .518 R/T on a .500 light
Need more speed xvii Integra 10 10-16-2005 11:38 PM
Need more speed...trying to take off govenor...any suggestions?? jackel1028 Ranger | Courier 1 04-19-2004 01:30 PM
SL...needing more speed... GTO4Life 3000GT/Stealth 14 03-06-2004 12:55 PM
Need more Speed, B18B1 Powered 95 Civic ex IntegraB18LS Engineering/ Technical 2 12-02-2003 11:22 AM
97 z28 needs more speed fatboys57 Camaro Discussions 16 05-13-2003 07:05 PM
