Go Back   Automotive Forums Car Chat > AF in General > AF News
AF News Find out what's happening here at AutomotiveForums.com
Old 09-20-2003, 11:02 AM
igor@af's Avatar
igor@af igor@af is offline
Your friendly AF Admin
Send a message via ICQ to igor@af Send a message via AIM to igor@af
Progress in pinpointing the issue
After more than 40 cumulative hours of work by both professional server techs and myself, we have been able to finally pinpoint the problem. It appears to reside with a faulty mysql query that is initially executed for every page by every user while they are browsing the message board. On the current setup of running everything on one server, this query takes
0.015040993690491 seconds
keep in mind that this is with dozens if not a hundred concurrent users accessing the message board at the same time.
However, this exact same query takes
1.5099580287933 seconds
to execute on the new database server when there is absolutely no one except for myself accessing the database.
This is most likely why the server choked whenever we tried to switch to using the remote database.
I am hoping to have the second server running without issues by the end of today. Wish us luck!
Welcome to the Revolution
Old 09-20-2003, 11:06 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Good luck, our firendly admin!
Old 09-20-2003, 07:36 PM
badassgremlin badassgremlin is offline
Send a message via AIM to badassgremlin Send a message via Yahoo to badassgremlin
well i guess you gotta fight for your right to party.......good luck man.
1993 Buick Regal GS 3.8L Hydramatic 4T60E
Old 09-21-2003, 01:30 PM
Import_Tuner's Avatar
Import_Tuner Import_Tuner is offline
Send a message via AIM to Import_Tuner Send a message via MSN to Import_Tuner
Hey
I used to run a decent website with a forum and also had a mySQL database and when I first set it up it was hell but then I got there and im sure you will too. Thanks for trying to get us all the best service, keep it up friendly admin!
--Chris
Proud Moderator of Banzai Magazine Forum
http://www.banzaimagazine.com
Old 09-22-2003, 09:54 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Gotta say I am not a big fan of mySQL yet. I’ve spent to much time in MSSQL, Oracle and I’ve spent to much time in MSSQL, Oracle and Interbase then mySQL. Open source is ok, but it does have its limitations and support issues that you don’t get with the others.
Hope everything works out tuning the server. Looking forward to the better and faster AF
Resistance Is Futile (If < 1ohm)
Old 09-22-2003, 08:11 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Good luck Igor. And take all the time you need, I see no need to rush perfection.
*Under Construction - New sig to debut*
Old 09-22-2003, 09:17 PM
igor@af's Avatar
UPDATE:
The theory on how to fully resolve the issue has been perfected and all that is left now is to execute it. PHP will need to be recompiled with some special options and the coding required for the change should be done sometime tomorrow.
Old 09-23-2003, 04:19 PM
Yay For A $7,000 Server! Igor You Da Man!
HTML code is On
