Old 09-20-2003, 04:53 AM
93DXon18s 93DXon18s is offline
SiR2 Block From Japan w/ Internals...
im buying and SiR2 block from japan w/ the internals but i have 2 questions:
1...because its from japan(JDM), will i have to change my civic to RH drive or is that only when the engine is 'jap spec'?
2...what are the best parts i can use on the block, meaning can i use any b series parts? Basically, i just want to know what are the possibilities i can end up with and will it hurt me to use USDM parts on a JDM block?
Old 09-20-2003, 07:24 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: SiR2 Block From Japan w/ Internals...
You really need to do a LOT of research, and I mean a LOT.
No you don't have to change your car to RHD.
Old 09-20-2003, 08:07 AM
im trying to do alot of research...the whole reason i am asking. i know b series parts fit b series blocks but i want to know what would be the best configuration to use? its just the block, crank, rods, pistons, water pump, fuel pump and some other accessories. What kind of head should i get and the best intake manifold. im looking to build a great engine and i just want sum tips. i dont need ALOT of research like u say, just sum...which is why i am asking about the things i dont exactly know yet, duh. i dunno if u were trying to say i have no clue as to what im talking about or not but i do know alot about this subject...just not everything
Old 09-20-2003, 09:35 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
just get yourself the b16B head from that motor and you'll be fine.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-21-2003, 12:52 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
1. No, you can keep it LHD.
2. All B-series parts are interchangable, and no, it wont hurt to put USDM stuff in a JDM block.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-21-2003, 02:07 PM
No, not all B series parts are just "interchangable", for instance OBD issues. You can't put a GSR intake manifold on a ITR/CTR/B16A head, without modification. You can't just drop a B16A head on a B18B block. 1st gen B16A and 2nd gen thermostat housings are different. And I'd like to see someone cram B20 pistons in a stock bore B16A block, or B16A pistons in a B20. Not to mention rod lengths between motors. Also some of the older motors have different output shaft diameters for the tranny, and so on.
