Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-19-2003, 08:41 PM
96HondaCivic 96HondaCivic is offline
Brake Rotors
I know this might be a stupid questions but i aint too familiar with brake rotors. I wanna know if i want to upgrade my disk rotors to drilled and slotted or maybe just drilled, will they be any bigger or will they be the same size as the old ones??
*- '96 Honda Civic Lx 4 Dr Auto -*
*- CAI 2.5in w/aem bypass -*
*- Invidia High Performance Cat-Back Exhaust -*
*- Suno Hyper Ground System -*
*- Front Upper & Rear Upper Strut Bars -*
*- Dc Sports Rear Lower Strut Bar -*
*- Tom's Lowering Springs 1.5in -*
*- 16X7 Konig Blatants w/ 215/45 Falken Azenis -*
*- Power Stop Slotted rotors -*
*- G-Force 5 Points Harnesses(Only using 4 points) For autocross -*
Old 09-19-2003, 09:17 PM
BullShifter's Avatar
Let me ax you sumthin'
Are you upgrading for performance or looks?
It really depends which rotor's you get, some are OEM spec while others are larger.
Old 09-19-2003, 09:28 PM
I wanna do for performance cause mine are startting so squeek. Is their any way to make the rotors bigger without messing around with the caliper??Or do i have to get a big brake upgrade kit?
Old 09-19-2003, 09:45 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Brake Rotors
Actually all that cross drilled and slotted stuff is crap. I went from cross drilled/slotted Power Stop rotors to Brembo blanks with the same pads (AEMs) and my stopping power increased 10fold. Braking power comes from more surface area. When you start taking material out of the rotor you have less surface area to use for braking.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 09-19-2003, 10:03 PM
hondaracer hondaracer is offline
Re: Brake Rotors
Don't ever get drilled rotors cause later on they are known to crack. If anything get slotted rotors to help with the brake cooling. Also when you do get a bigger rotor, which you should, you will have to relocate the oem caliper or unless you want to pay 1100 for one of those big brake upgrade kits which come with 4-piston calipers. But you can get just a big rotor upgrade which is only 400 by aem. But you also need bigger rims for clearance if you dont already have them.....
Old 09-19-2003, 11:38 PM
Thats a good point about cross drilled cracking, I have dimpled rotors on the vette. Dont go installing racing brake pads with your new set-up, you'll never get them hot enough to function correctly on the street. Plus they are noisy as hell. Sounds like a big ass semi stopping - minus the air brake noise.
Old 09-20-2003, 08:03 PM
Thatnks for the advice about the drilled rotors. Ok but how can I make my stock rotors bigger without upgrading them with a big brake kit??
Old 09-20-2003, 08:36 PM
Re: Brake Rotors
Ok 96HondaCivic..... Stock rotors don't get bigger. There is a kit from aem that will give you a big rotor upgrade that costs 400. It comes with two big rotors, steel lines, and relocation brackets for your oem caliper. There is no caliper upgrade kit in this so your keeping the stock calipers and it doesn't cost 1000 like those big brake upgrade kits do. Also if you don't have rear disc brakes, I would recommend getting a conversion kit because you will feel a big difference with 4 wheel disc brakes. That kit cost about 800 but all wortj it in the end.
Old 09-21-2003, 12:23 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Rotor size is relative to the clamping force and surface area of the pad.
Without a larger caliper, and pad surface area a larger rotor will do nothing.
Heat is a braking systems enemy. On our cars it is hard to reduce heat. Without running some type of venting to the brakes. And I doubt you would ever be in a situation like.
The best think to do is if you road race, or even if you don't get a set of Brembo blanks as SiRacer mentioned, and some sport pads. And make sure you have new brake fluid, or at least have the lines bled.
Stainless steel lines help as well with braking modulation, it decreases the line expansion from heat, which gives the car a more stable feel when braking.
Sport pads, Non-slotted/drilled rotors will make a world of difference for you.
If you race hard enough where you are overheating the brakes, the pads and rotors should be changed every race anyway, especially if you wind up boiling the brake fluid.
I don't think you are into that kind of racing anyway.
M.Sanew - AutomotiveArticles.com
Old 09-21-2003, 05:07 PM
Does anyone know if Aem makes the big brake kit for a 96 civic lx?
Old 09-21-2003, 11:59 PM
http://www.aempower.com/product_brake.asp
look yourself lazy ass
Why not get some of theses?
Old 09-22-2003, 01:19 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Brake Rotors
Just so your aware, the AEM kit is better being showed off at a show than it is for any sort of performance stopping or driving. Something to keep in mind.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 09-22-2003, 08:17 AM
Civic Mod
Re: Re: Brake Rotors
Right because it uses the stock calipers and master cylinder. I know guys who do track days on their stock sized brakes with no problems. Just a little extra ducting and better pads/fluid.
Autocross Help Page
Buy my Civic parts!
Front Brake Job - Replace Rotors? buickultra2000 Park Avenue 3 02-09-2010 07:11 PM
Changing rotors on 02 Outback` ecamc Outback 1 09-01-2009 07:32 PM
02 Silverado shakes when braking. kegster Silverado 17 07-17-2009 07:57 AM
New Brake Pads Grinding Rotors HELP williamjay199 Taurus | Taurus Wagon 1 07-13-2009 11:51 AM
