Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 09-19-2003, 06:43 PM
HazenL HazenL is offline
Slow Starting,2002 540
My lovely 2002 540 6 speed has taken to occasionally needing about 10 seconds of cranking before it will start. No apparent pattern, about one time in three. The BMW dealer in Greenville S.C replaced a fuel system valve, suspecting bleed off when shut down. No impact. Hints ? Thanks.
Old 09-19-2003, 08:23 PM
TheScientist's Avatar
TheScientist TheScientist is offline
Banned
what do you mean cranking?
Old 09-20-2003, 05:21 AM
By "cranking", I mean that I turn the key to the start position, and the starter motor kicks in and turns the engine over rapidly(normal fast start turn over speed), but the motor does not fire. Two times in three, it starts with 2 seconds of cranking, but one time in three it turns and turns for about 10 seconds.
Old 09-20-2003, 10:59 AM
Banned
You sure your holding the clutch all the way down, and the trans is in neutral? Also, when you try to start the car, whats it sound like, does it sound like the starter is working, but the plugs are getting no spark, or the starter really doesnt work well?
Old 10-10-2003, 09:34 PM
DeRath DeRath is offline
sounds like fuel pressure problem, I would have replaced the fuel pressure regulator, (sounds like the dealer did that). could also be fuel pump, fuel pump relay, ECU, etc.etc. this kind of problem may take a while to find.
96 Taurus slow cranking bukuballs Taurus | Taurus Wagon 6 06-07-2011 06:25 PM
97 LT Astro Slow start, no start ckmn M Bodies 6 03-07-2006 07:52 AM
1990 900 S slow starting Rufus DeRouen 900 1 05-09-2004 05:21 PM
slow starting vortec OLD BULL C/K 5 02-29-2004 08:49 AM
Slow start. szymek25c Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 6 06-06-2002 04:53 PM
