Old 09-19-2003, 06:44 AM
kinky kinky is offline
Heating/coolant problem
1994 Taurus wagon (3.8L)
Bought a used Tarus wagon with 106,000 miles on it. New radiator had been installed. Noticed the temp gauge to push upper limit at times and then drop. It repeated this over and over. When it was peaking, no heat, when it dropped, heat. Replaced the thermostat....same problem. I opened the radiator cap and there was a bunh of gunk around the inside.
When I tried opening the drain cock on the radiator, all that came out was a few dribbles of brownish liquid. The overflow resevoir is at the right level of coolant.
Help!!!
Old 09-19-2003, 07:22 AM
Alex_Perry Alex_Perry is offline
go to a lube shop and get a pressure flush done.
Old 09-19-2003, 10:20 PM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Check the condition of the hoses too. Especially the bottom one. Replace it if it's at all questionable!
Old 09-22-2003, 07:16 AM
Pressure flush did the job
Thanks!!
Old 09-22-2003, 07:26 AM
good to hear!
Coolant/Over heating problem Poyntons Legacy / Liberty / Baja 8 03-21-2010 02:52 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
Heating/Coolant Problem gthompson97 Off-Topic 1 05-16-2005 04:45 PM
97 Ford Tauras Heating/Coolant/Temprature KaseyRae Taurus | Taurus Wagon 3 12-08-2004 08:09 AM
93 blazer overheating, no heat, coolant boiling out of reservoir Help! Feelinbeefy Blazer 1 02-01-2004 01:19 AM
