Go Back   Automotive Forums Car Chat > Dodge > Viper | Viper SRT19 Roadster
Old 09-18-2003, 06:17 PM
bdub bdub is offline
Lightbulb Mustang SC on a stock Viper?
Thinking about purchasing a used Viper in the next 18 monthes, and don't have the money for "authentic" Viper upgrades. I know I can make it fit, would a off the shelf supercharger for a camaro/mustang work on a stock viper? Something around 10-12 pounds of boost? Is a Viper intake/mass air a similar setup to the pony cars? Would the stock parts reliably hold up to this?
Thanks, Bdub
Old 09-19-2003, 07:07 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I'm guessing not.
*Under Construction - New sig to debut*
Old 09-20-2003, 01:33 AM
Viper 10 Viper 10 is offline
It won't work for several reasons.
First of all, the volume of air moved by the Mustang blower is not sufficient for a Viper's very long engine block. There is a high likelihood that you would starve the back cylinders (which would probably be fatal). Detonation can be fatal on a Viper engine.
Secondly, there are many who try to add blowers to Vipers with limited success. The main reason that they fail is because they don't change out the ignition and fuel management computer. If done correctly, this would be one of the largest investments that you would make.
Finally, most Mustang applications don't use sufficient intercoolers. This is absolutely where the largest investment should be made (and where most people neglect). I could go on about the need to drop compression, hypereutectic pistons and more, but I won't.
The bottom line is don't do it. Save your money for driving school and don't worry about building a dyno queen. I hope that this answers your questions.
JMO.
"We will always remember. We will always be proud. We will always be prepared, so we may always be free."- Ronald Reagan at the D-Day Anniversary
Old 09-20-2003, 11:31 PM
Whitebread Whitebread is offline
I say you don't bother with a S/C untill you learn how to drive the car and can push it to it's limits in terms of lap times, drag times or whatever you do. Also, suspension and drive train mods would probably be better wiht a viper. 500HP and 400+ pound feet of torque is a crap load.
