Old 09-18-2003, 04:30 PM
rschink rschink is offline
Question No brake lights on rear of truck
I have a 98 Z71 with no brake lights. I have checked fuses, bulbs and all are fine. I have the brake light on top of the cab and all of the taillights, turn signal, park and reverse lights work. Any help would be greatly appreciated.
Old 09-18-2003, 05:05 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Check the brake lamp switch.
remove the taillamp assembly and check for power at the connector. If you have power at the connector when the brakes are pushed, then the switch and wiring to that point is good. You may have a bad circuit board assembly at the tailamp
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-22-2003, 09:28 PM
KRAZYMATT36 KRAZYMATT36 is offline
i have a 99 extended cab i have almost same trouble but opposite my brake lights on my bed work my turn signals work but my third brake lights do not. my cargo lamps work. i dont know what the deal is.
-krazymatt
Old 11-25-2003, 09:24 AM
carl1952 carl1952 is offline
Re: No brake lights on rear of truck
I just went thru this with my 1990 K1500. My flashers and turn singles worked but no brakes. I traced the wiring schematics and found only one trace that could make the bk lights not work. It was in the turn single/hazard assy. Replaced it and all is back to normal.
Old 11-27-2003, 11:15 PM
tooltimetech tooltimetech is offline
Sounds like a turn signal switch problem.
