Old 09-17-2003, 09:51 PM
WPowissr WPowissr is offline
Question Wiring Diagram for 2000 Caravan
I have a 2000 Dodge Caravan that was not prewired for RKE (remote keyless entry). Where can I get a wiring diagram for this vehicle so I can see where the RKE should be connected in? I already have the MOPAR RKE for this model but do not know where to connect it. I know that there are only four connections and two are +12 v and ground. One of the others is for the door "lock and unlock" function and the other is for the "Panic" function. Thanks, Walt Powis [email protected]
Old 10-25-2003, 10:40 PM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
2000 Dodge Caravan Security Information
Constant 12V+ Red or Pink/Black Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Dark Blue Ignition Switch Harness
Ignition 2 Dark Green/Red Ignition Switch Harness
Accessory Black/White Ignition Switch Harness
Tach Gray/Red Or Blue/Tan PCM Coil 2.4 Liter Engine
Neutral Safety Wire Black/White Power Control Module
Brake Switch White/Tan Brake Switch
Trunk Pin Tan/Black 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) Head Light Switch Harness left of Column
Head Lamp Green/Orange Light Switch
Hood Pin Brown Driver's Side under Hood
Factory Disarm White/Dark Green (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green (-) BCM at Fuse Panel 1500 Ohm Resistor
Door Unlock White/Dark Green (-) White Connector B58 Connector 250 Ohm Resistor
Driver's Lock Brown (+) Junction Block
Driver's Unlock Purple/Yellow (+) Junction Block
Horn Wire Black/Red Steering Column
Windows Up LF=Light Green, RF=Brown, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple, LR=Red, RR=Dark Green
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
