Old 09-17-2003, 08:52 AM
fairladyz_gt-r's Avatar
fairladyz_gt-r fairladyz_gt-r is offline
Send a message via AIM to fairladyz_gt-r Send a message via Yahoo to fairladyz_gt-r
Unhappy need help on sanding
I messup on the sanding on my Enzo. the to part of the concle*spelling didn't come out smooth i need to sand it down and respray it. but for my pass expreience*spelling i messup alot of time already so this time i am asking ur pros for help!
Old 09-17-2003, 09:17 AM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
use a very fine grade paper (1000+ grit) and just remove very small amounts at a time. keep checking your progress, if you use to heavy a sandpaper you will remove far too much in one go.
Just take your time, and use very very fine paper to finish the piece for paint
Old 09-17-2003, 10:43 AM
Thx u soooo much!~
Old 09-17-2003, 10:50 AM
Murray Kish Murray Kish is offline
Getting Old...
I find it hard to get a smooth surface on things that are 'irregular' shaped. I always seem to dig a gouge somewhere or end up with an 'uneven' job. I've started using rubbing compound to do some of the finish sanding on these pieces. Just put a little on a toothbrush, and scrub away.
FYI, the stuff I use is just the Turtle Wax brand normally used for cars. It comes in a red 'tub' about 2" high and 4-5" across and will last me forever. It's quite abrasive and does a good job. Just rinse the part off and with soapy water and another toothbrush when you're done.
Note that it is quite a bit more abrasive than polishing compound that many people use here for their final paint treatment, so don't confuse the two.
Murray
