Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-16-2003, 11:37 AM
chohouston chohouston is offline
Send a message via AIM to chohouston Send a message via MSN to chohouston
Eibach Pro kit for 2003 honda civic
Anyone know if an eibach pro kit will do for my 2003 honda civic Si-G (same as ex)?
I just want to lower my car with better handling while getting rid of my tire well. I am putting 17" rims with performance tires. Is it a necessity that I get shocks, alignment kits and and anti roll kit?
Old 09-17-2003, 01:11 AM
BullShifter's Avatar
Eibach Pro-Kit is a nice set of springs.
Yes you shouldreplace the shocks/struts when lowering.
If your looking to get the most out of your suspension(handling) then a rear sway bar upgrade should be done. The stock front bar will do with poly bushings & end links. My car has way too much understeer with a larger sway bar in the front so I use the stocker with bushings. Front-wheel drive cars benefit from a rear sway bar while RWD benefits from a front sway bar. IMO a rear lower tie bar should be used with a rear sway upgrade.
You shouldn't need a camber kit unless you go under 2" drop or plan on racing.
Old 09-17-2003, 03:59 PM
thanks jackass!
that will probably cost me a few bucks...but it should be worth it...
Old 09-17-2003, 11:10 PM
Re: Eibach Pro kit for 2003 honda civic
Originally Posted by chohouston
thanks jackass!
It will be well worth the extra money. Theres nothing worse than a shitty riding modified suspension(lowered). Adjustable shocks are worth the extra money, even for street only use IMO.
For Sale 2003 Honda Civic EX Coupe, 108k miles chelsevans851 Cars/Parts for Sale/Exchange 0 09-23-2010 01:26 PM
Eibach Pro Kit For Sale jaw187 Neon | Plymouth Neon 0 11-29-2003 06:23 PM
camber kits for a honda civic drux Tires and Wheels 1 01-19-2003 05:12 PM
eibach pro-kit for p10 uclandru Suspension 1 01-24-2002 03:48 AM
