Old 09-15-2003, 11:19 PM
ermis33 ermis33 is offline
Send a message via AIM to ermis33
Unhappy 00 sputtering when give gas
Hello, I am new to this forum but am looking for some help. I own a 00 Silverado with 58,000 miles on it. Here recently I have noted it starting to sputter when I give it gas at take off and when I am driving. I canged the fuel filter but that has not helped. I dont know if this question has come up here before or if it has already been answered but any help would be great. It is sort of a jerking movement when I give it gas. Timing off, new wires/plugs? If anyone else has experienced this please let me know.
Thanks
Matt
Old 09-16-2003, 03:17 PM
Re: 00 sputtering when give gas
Thanks
Matt
Ok I guess I am screwed. No one has heard of this.
Old 09-17-2003, 10:02 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
This happened to me. Its the fuel pressure regulator. Well it was a combo of that and a clogged fuel filter in my truck. It fixed it.
*Under Construction - New sig to debut*
Old 09-17-2003, 06:46 PM
Mrouff Mrouff is offline
Hey Matt, I had a similar problem with my truck. I had a new fuel pump and filter installed, which they assured me should fix the problem. It turns out that I also had some cylinder damage though (see my posting from earlier today), so I can't confirm that the fuel pump/filter repair has worked yet. It wouldn't hurt to check your spark plugs as well. Not sure if that helps at all, but just thought I should pass that on.
-Mark
Old 09-18-2003, 05:48 PM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
Could also need to just clean up your fuel injectors with some fuel injector cleaner available at your local automotive store. That or it could be a timing problem which would be bad.
Old 09-22-2003, 05:30 AM
sc_customs's Avatar
Just fixed a somewhat similar problem on my buddy's truck. The truck would sputter if you gave it gas appropiately. If you floored it there wouldn't be a sputter. I noticed his serpentine belt was quite worn so we got a new one and it solved the problem.
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
Old 09-25-2003, 01:18 PM
Found Problem!
Just thought I would let yall know in case this happens to any of you. The ignition coil had gone out. I replaced that and it hasnt missed a beat since. Originally I flushed my injectors and changed the fuel filter. Still was doing it. The replaced coil fixed it. Hope this might help someone one day.
Old 11-11-2003, 09:00 PM
dogdrake dogdrake is offline
how did you know which one to fix.did you read it with a meter? or check for spark on all the coils.my truck has the same problem. it does it sometimes.
Old 11-12-2003, 10:50 AM
hmoritz hmoritz is offline
My truck does the same thing. Everything mentioned has been replaced and still does it. I bought the truck at the dealership I worked at and the mechanics say its normal. BS - I say...but what can you do? I use an Octane boost everytime I fill up and it seems to help. Good luck!
