gauge lights going out one by one
It all started with the lights on the fuel gauge then months later lights going out on the other side of the cluster, only the ones straight up the middle are working. How much should I expect to pay for replacements?
Re: gauge lights going out one by one
When you have this condition, I would suspect loose connection problems---like maybe circuit board securing screws have worked loose. I had this very problem a couple times on an 80 Buick dash circuit board. |
I have the same problem on my 97 Explorer. The guage lights on either side are out, and I can just barely make out the speedometer and the tach. Is it definitely a loose connection? Or, maybe some burnt out bulbs? Is there a way to fix/replace the bulbs yourself? Thx!
I'm not familiar with a Ford Explorer. I'm a TV technician that is very familiar with electrical problems. 99 percent of the time when there is an intermittent electrical problem in anything, it generally turns out to be a loose connection--not a wire hanging loose--but a solder connection that has cracked or a mounting screw that is not tight which serves as a connection. Like, in my other post I had screws work loose on a circuit board behind the dash in an 80 Buick that caused panel light problems. So, to specifically give an answer to the 97 Ford Exp. I can't.
Have a 99 with the same problem. Dealer told me that it would cost $78 for the circuit board and $130 in labor. Can I really fix it myself?
I'd try ExplorerFX's fix 1st. It's cheaper than replacing instrument cluster. It's usually the bulbs. Not too many clusters go bad. If it doesn't work you can always have Ford replace the cluster. You can replace it yourself, It's
pretty much the same procedure that ExploreFX outlined except you replace the cluster. Good Luck. Let us know how it went. |
Re: Re: gauge lights going out one by one
dash bulbs
i just replaced the dash bulbs in my 97 explorer. its not too difficult. the only thing you have to be careful with is the gear selecter cable. ot is a thin brown wire. if you tug on the gauge cluster too hard it will break. the bulbs were slyvannia #194 . there are four bulbs total. if you flip the gauge cluster you will see 4 black bulb recepticles. turn them a quarter turn and they will pop out. hope this helps.
