Old 09-15-2003, 05:44 PM
Myjunkistight Myjunkistight is offline
Unhappy ZC engine bogging
I have just installed a Dohc ZC engine into my 90 Crx si. It idles fine but when I mash the throttle it bogs until around 4K rpm's then it revs smoothly. If I slowly hit the throttle it runs fine. I have heard that it could be a bad O2 sensor. Mabye bad plug wires? My plugs are fairly new so I don't think that their the problem. Any Suggestions?
Old 09-18-2003, 05:27 AM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
mines does the samething soon after u crank it....let it warm up for a few mins then see if it does it. i let mine warm up a few mins, then it drives just fine
Old 09-19-2003, 02:09 PM
It only does it once it warms up, today was my first day actually taking it out of the garage and the first time I took it out it was running awesome, and then I took it back to adjust the clutch cable and when I went back out it started bogging like crazy. I just happened to see a ricer on my second time out and thought it would be fun to try the engine out and to my suprise I get smoked by a stock civic ex. That really hurt my feelings, I thought I was gonna cry. The engine hardly even starts now. It bogs really bad at low rpms making it difficult to get going. And if I try to acclerate it bogs really bad. If I hold the acclerater down for a few seconds it will bog at first, then try to get going, and then bog back down again. It's like its trying to run good. I am going to take it into a shop and get a tuneup and have them check everything on monday. Any help would be appreciated though.
Old 09-22-2003, 02:36 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Did you adjust the clutch cable incorrectly? You sure it was the clutch cable you adjusted?
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 09-22-2003, 12:02 PM
Smile
I figured it out! Check this, it was the plug wires. I just plugged the ones from the d16 in and it revved up perfect. I ordered some accel plugs from nopi. Now its time to go look for that civic! Thanks for the info guys.
zc engine bog at WOT... codes 7/14 89stdzc '88 - '91 Civic | CRX | Wagon | Shuttlee 11 03-27-2004 11:24 AM
ZC engine bogs out.. code 7/14 89stdzc Engineering/ Technical 2 03-24-2004 07:02 PM
Engine bogs down and dies ivan8r C/K 1 09-05-2003 03:54 PM
Engine bogs upon starting teaminvasion Integra 5 08-29-2003 01:30 PM
3rd Gear Engine Bog allstarMEj General Discussions 0 06-29-2003 02:51 PM
