Old 09-15-2003, 03:16 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
shift linkage and ecu ???'s
I just got a 89 crx si and i put in my short shifter with new bushings, but it is all on a 90 si shift linkage...sometimes it hits the exhaust..is this because it is for a 90 not a 89...I can just put it all on the 89, but I got it all on the 90 shift linkage so instead of changing it all over I just threw it on. Also I have a spare 91 si ecu and I was wondering if the 90-91 ecu's are any better than the 88-89. Thanx for your help and I am waiting to get my pictures back so I can post pics of the car.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 09-15-2003, 11:47 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Your short shifter is more than likely the cause of banging the exhaust.
88-91 ECU's are the same,
Old 09-16-2003, 02:59 AM
91civicDXdude's Avatar
88-91 ECUs are not the same.
the 88 and 89 ECU uses the same architecture as the old style PG7 integra ECU.. that is, the EPROM is located inside of the microprocessor, making it impossible to chip. the 90-91 PM6 has an external EPROM which makes for easy chipping.
Also, its been said that ECU tuning makes up the extra 3hp gained from 89-90. (88-91 D16A6 is 105hp while the 90-91 is rated at 108hp)
Old 09-16-2003, 03:11 AM
kris's Avatar
Re: shift linkage and ecu ???'s
Learn something new everyday.
But, as far as a mildly modified civic. Would a 90/91 really be that much better to use over the 88/89, if ecu tuning was not going to be done?
Old 09-16-2003, 07:47 AM
Thanx a lot for your replys. I know that it is my short shifter that is making the noise on my exhaust I just did not know if it was because of the linkage. I am going to take it apart again today and see if I can figure it out. Also with the ecu's I am just going to throw in the 90-91 ecu since I have it. Thanx again.
1989 Crx Si
-thermal cat back
-Hx wheels
Old 09-16-2003, 10:17 AM
kris's Avatar
The shifter bangs because it is longer.
Old 09-16-2003, 10:33 AM
Re: Re: shift linkage and ecu ???'s
So this is normal from the skunk2 hort shifters or from the shift linkage?
1989 Crx Si
-thermal cat back
-Hx wheels
95 s10 v8 shifter linkage and various ?'s Wingman83 S-10 1 12-03-2009 12:16 AM
2005 Wrangler shift cable linkage DrRadar Wrangler 1 04-14-2009 11:24 AM
b16a shift linkage and axles question jlshondacrx90 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-12-2005 07:19 PM
shift linkage and turbo hose HELPPPP TURBOROOKIE Probe 0 01-10-2005 07:18 PM
