Old 09-15-2003, 07:51 AM
gsf1200m gsf1200m is offline
air/fuel gauge question
I think this might be kinda a weird question.
Is an a/f gauge the kind of gauge you would put on the pillar so it is very visible like witht the oil pressure and water temp gauges, or is it more the kind that is hidden like under the dash or soemthing?
Or is it just personal preference?
Old 09-15-2003, 10:10 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
The a/f ratio gauge is something you want to see. It's not just pretty, it's actually functional. I have mine on my pillar & I use it every day to keep from getting a Code 1 (that just my car though & I'm tired of buying O2 sensors ).
IMO the a/f gauge is going to be more beneficial than just about any other (aftermarket) gauge you could install...
Old 09-15-2003, 12:31 PM
Thanks, thats what i was looking for.
I would rather go with function than looks.
Old 09-15-2003, 11:49 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: air/fuel gauge question
Then don't go with a Autometer a/f. gauge.
Old 09-16-2003, 06:46 AM
Ok, but how come? Just not as good quality as other ones?
Old 09-16-2003, 10:22 AM
kris's Avatar
If you plan on using it for any sorts of tuning, they are not really that accurate.
Old 09-16-2003, 12:31 PM
Do you mean the autometer one is not accurate for tuning, or that all air fuel gauges are not accurate?
Do you reccomend a certain one to use?
Old 09-17-2003, 10:33 AM
kris's Avatar
It's not just the autometer gauge itself, it's the stock O2 sensor. The stock O2 sensor is not accurate because it does not compensate for exhaust temperature. But, the autometer A/F gauge only has 20 LED's, which I guess looks really cool going back and forth. You would be better getting a A/F gauge with a digital readout, or actually dial, such as the Greddy kit. I know you can purchase the greddy dial, with a wide band O2. Apex'i and Halmeter are some other good brands. But still, they wont do what you need with a stock O2.
Old 09-17-2003, 11:14 AM
91civicDXdude's Avatar
I thought that was how an o2 sensor worked.. turns exhaust heat into an electronic pulse which can be measured to determine air/fuel ratio?
Old 09-17-2003, 03:56 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
where exactly does the A/F gauge get connected to?? just slice it into the O2 wire and ground it?? i have no idea, i'm interested in gettin one after the cars fixed, dont know where to mount it tho,
Old 09-17-2003, 04:44 PM
kris's Avatar
Not really.
There is a particular ratio of air and gasoline that is "perfect," and that ratio is 14.7:1 (different fuels have different perfect ratios -- the ratio depends on the amount of hydrogen and carbon found in a given amount of fuel). If there is less air than this perfect ratio, then there will be fuel left over after combustion (running rich). If there is more air than this perfect ratio, then there is excess oxygen (running lean).
Most O2 sensors involve a chemical reaction that generates a voltage. The ECU then reads the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly.
So with the Autometer A/F gauge, and its 20 LED lights. What is that really telling you on a narrow band, stock O2? Nothing, except for red, yellow, green.
Old 09-17-2003, 04:50 PM
kris's Avatar
Nope, you just tap the one wire into the O2 wire, either running off the O2, or near the ECU.
2000 Sportage Fuel Gauge Not Working...HELP!! hottmpr80 Sportage 1 08-03-2010 08:35 AM
Temperature and Fuel Gauge = Dead TESE Malibu 3 02-22-2010 06:45 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
Air/fuel gauge question... Turbodog97 Off-Topic 3 02-02-2006 09:58 PM
