Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-14-2003, 09:57 PM
toyquarius toyquarius is offline
a quick question
is it normal for the maintenance light on a 95 integra rs non vtec to flash for like 20 seconds on start up then go out . i just bought the car and am new to it. I changed the oil and coolant and fuel filter when i bought it , and i wondered if it isnt normal does it need to be reset?
Old 09-14-2003, 10:01 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
wut u need to do is complete the circuit at the ecu (which is located on the passenger side by where their feet would be), an then turn the car to acc (two clicks) an then tell us how many times it flashes.
u can look up online (try google.com) the exact how-to of reading the codes, but its very basic so u shouldn't have too many problems. once u figure that out (how many flashes) we can tell u wut the problem is.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 09-16-2003, 01:48 AM
Vtec Vtec is offline
For example, eight long flashes and six short flashes equals 86
Code 01 is equal to one short flash, Code 10 is equal to one long flash
# DETECTION ITEM PROBABLE CAUSE
OBD-I / OBD-II (1988-Present)
00 ECU Defective ECU
01 Primary O2 sensor Open or short in O2 sensor circuit, defective Primary O2 sensor
02 Secondary O2 sensor Open or short in O2 sensor circuit, defective Secondary O2 sensor
03 Manifold Absolute Pressure sensor Open or short in MAP sensor circuit, defective MAP sesnor
04 Crankshaft Position sensor Timing belt slipped, defective CP sensor
05 Manifold Absolute Pressure sensor Reading too low or too high, defective MAP sensor
06 Engine Coolant Temp circuit Reading too low or too high, open or short in circuit, defective ECT circuit
07 Throttle Position circuit Reading too low or too high, open or short in circuit, defective TPS circuit
08 Top Dead Center sensor Open or short in TDC sensor circuit, defective TDC sensor
09 Cylinder Position sensor Open or short in CYP sensor circuit, defective CYP sensor
10 Intake Air Temperature sensor Open or short in IAT sensor circuit, defective IAT sensor
12 Exhaust Gas Recirculation Valve Open or short in EGR valve circuit, defective EGR valve
13 Barometric Pressure sensor circuit Defective ECM (Barometric sensor)
14 Idle Control System Malfunction Defective IAC valve, defective fast idle thermo valve, throttle body
15 Ignition Output Signal Missing, defective or noisy Ignition Output Signal
16 Fuel Injector System Defective or malfunctioning Fuel Injector System
17 Vehicle Speed sensor circuit Open or short in VS sensor circuit, defective VS sensor
19 Lock-up Control Solenoid Open or short in LCS circuit, defective LCS solenoid
20 Electrical Load Detector circuit Open or short in ELD circuit, defective ELD circuit
21 VTEC Solenoid Valve Open or short in VTEC solenoid valve circuit, defective VTEC solenoid valve
22 VTEC Oil Pressure Switch Open or short in VTEC OPS circuit, defective VTEC pressure switch
23 Knock sensor circuit Open or short in Knock sensor circuit, defective Knock sensor circuit
30 A/T FI Signal A high/low input Defective AFSA line, TCM
31 A/T FI Signal B high/low input Defective AFSB line, TCM
41 Primary Heated O2 sensor heater circuit Open or short in Primary O2 sensor heater circuit, defective Primary O2 sensor heater circuit
43 Fuel Supply System Defective or malfunctioning Fuel Supply System
45 System too lean/rich Fuel supply system, Primary O2 sensor, MAP sensor, contaminated fuel, valve clearance, exhaust leakage
48 Lean Air Fuel sensor Open or short in Lean Air Fuel sensor circuit, defective Lean Air Fuel sensor
54 Crankshaft Speed Fluctuation sensor Open or short in CKF sensor circuit, defective CKF sensor circuit
58 Top Dead Center sensor #2 Open or short in TDC sensor circuit, defective TDC sensor
61 Primary Heated O2 sensor Slow response, exhaust leak, defective Primary Heated O2 sensor
63 Secondary Heated O2 sensor Slow response, exhaust leak, defective Secondary Heated O2 sensor
65 Secondary Heated O2 sensor circuit Open or short in Secondary Heated O2 sensor circuit, defective Secondary Heated O2 sensor circuit
OBD-II ONLY (1996-Present)
67 Catalyst System Efficiency System below threshold, defective catalytic converter
70 Automatic Transaxle A/T transmission, A/T FI data line, TCM, ECM
71 Random Misfire (Cylinder 1) Ignition system, fuel supply system, MAP sensor, IAC valve, contaminated fuel, lack of fuel, fuel injector,fuel injector circuit, low compression, valve clearance
72 Random Misfire (Cylinder 2)
73 Random Misfire (Cylinder 3)
74 Random Misfire (Cylinder 4)
75 Random Misfire (Cylinder 5)
76 Random Misfire (Cylinder 6)
80 Exhaust Gas Re-circulation Malfunction with EGR system, insufficient flow
86 Engine Coolant Temp circuit Defective ECT sensor, defective cooling system
90 Evaporative Emission Control System Fuel cap loose, poor vacuum connection, fuel tank, fuel tank pressure sensor, EVAP bypass solenoid valve,EVAP tow-way valve, EVAP control canister vent shut valve, EVAP canister, EVAP purge control solenoid valve
91 Fuel Tank Pressure sensor circuit Possible leak in the Fuel Tank Emissions System, open or short in FTP sensor circuit, defective FTP sensor circuit
92 Evaporative Emission Control System Insufficient Purge Flow or Defective Emissions System
I saved this for one time when I was trying to read codes.
Old 09-17-2003, 03:00 AM
where to check
i know on my old toyota pu i had to short two connnections under the hood to give me codes, but where is it on these cars and what terminals do i short out?
