Okay, I am getting the "Service Engine Soon" light on my 1998 Olds Intrigue. It has about 91K miles. Hooked up the computer and got the P1441 code. I know it means "evap control system flow during non-purge". I just don't know what "evap control system flow during non-purge" means
. Please help! Thanks! |
This means that the EVAP system is monitoring a constant change in pressure.
Most likely the canister purge valve or vacum valve is stuck open allowing engine vacum into the fuel tank. Also if you have had any work done and the vacum lines were installed backwards, this will also cause your problem.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
I just bought a used 2000 Intrigue with 75K miles. I took it home from the dealer and the service engine soon light came on. So I brought it back to have him fix it. He said his mechanic said it was a problem with the gas cap. Well, after he replaced that, the light still comes one. I am almost postive I am having the same problem. Is there any way this can be mistaken for a simple gas cap problem? Is it serious that I get it fixed right away? Thanks alot for your help.
Re: P1441 - Service Engine
It all depends on the code as to what the problem is...there are a few codes that are EVAP system specific.
First thing is to get a record of the code that is being set. Any time an EVAP code (for a leak) is present, I highly recommend that the system be tested even if a gas cap is left loose...this insures that the system is in fact operating as designed and that there are no other leaks that may turn the MIL back on.
