Old 09-13-2003, 06:00 PM
vwoolr vwoolr is offline
95 Ford Escort Cooling Fan
Cooing fan is not working causing engine to overheat. Two different mechanics have not fixed the problem. The last mechanic replaced the car computer. To date the cooling fan has not been replaced. Doe any on have any ideas ? Help !!! My email is [email protected]
Old 09-18-2003, 03:12 AM
SapphicCat SapphicCat is offline
First what did the two mechanics do for you?
And a few questions...
Have you tested the cooling fan?
Turn your heater on high, does the cooling fan engage and turn on?
Old 11-02-2003, 05:13 PM
baskin baskin is offline
I would imagine that between the two mechanics, one of them was bright enough to check the cooling fan before charging you what was probably 400 bucks to change the computer. You could always go with an aftermarket control. this one www.dccontrol.com is probably overkill for your application, but it's easy to install and going this route will provide a quick solution.
