Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-13-2003, 02:53 AM
Nismo31 Nismo31 is offline
Send a message via AIM to Nismo31
need a clutch!
hello everyone, my clutch is on it's way out, makes a grinding noise, i was told it mite be a loose bearing in the flywheel or something, doesnt make noise when in neutral or 3rd gear or higher..anyone have similar problem? also, im lookin for a good cheap clutch, something to get me thru the winter..any ideas??? thanks guys!
Old 09-13-2003, 10:34 AM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
just type in 240sx on an ebay search and you'll find a bunch of cheap stock replacement clutches.
Old 09-13-2003, 07:21 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Whatever you decide to get, make sure you use the proper torque settings for tightening it down. If you don't then you may end up with this...
A pressure plate in about 100 pieces
A blown apart bellhousing
A downpipe smashed in half from a flying piece of a pressure plate.
