Old 09-12-2003, 11:25 PM
crx hf crx hf is offline
90-93 TEG ecu work for my crx
Well i got ahold of a integra ecu of the 90-93 integra.Would it work with my setup.I have an HF with a SOHC ZC with a few mods.Also is there anything i should know before i switch out the ecu.Becouse ive never done it.
Old 09-13-2003, 12:16 AM
91civicDXdude's Avatar
technically, it will work. Oh, BTW, you could only use it direct plug-in if it was from 90-91, as the 92-93 tegs were OBD1. The ECU is a PR4, 6800 rev limit and very rich fuel maps. It will make the car run like crap most likely, or atleast thats my experience with using the pr4 on a sohc engine.
Old 09-13-2003, 01:25 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
im using the pr4 on my b18b instead of converting to obd1, i hope mine doesnt run like crap
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 09-13-2003, 02:02 AM
the OBD1 92-93 ECU is still called a pr4, and it should run okay with your B18B. the problem is with using a pr4 on a SOHC engine, especially 1.6L SOHC engine... it has less performance ability, less displacement, and so will receive too much fuel basically. It floods itself out.
Old 09-13-2003, 02:20 PM
What ecu would best fit my setup?I think the PM6 will
Old 09-13-2003, 02:30 PM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
pm6 should be fine on a mildly modded engine...right now im runnin a pg7 with no rev limit and remapped fuel and ign.
so whats wrong with a d15b2 again?
