Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 12-03-2001, 09:04 AM
buddha buddha is offline
my fogs are not working
how can you tell if your harness are melted ? both my fogs are out.. i checked the connectors to see if there are signs but they seem ok.. i fuse are ok.. what should i do next.?
Old 12-03-2001, 12:22 PM
kenchan's Avatar
kenchan kenchan is offline
check relay and switch
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 12-03-2001, 12:43 PM
checking the relay and switch
hi kenchan,
thankz for your suggestionz
how do you check the relays ? when i turn the switch to "on" and "off", there is a clicking noise.. does that mean that the switch is working?
i really appreciate any help you can give
buddha
Old 12-04-2001, 02:27 AM
pRiMeRaCeR pRiMeRaCeR is offline
Send a message via AIM to pRiMeRaCeR
first, did u check to see if you blew your bulbs?
your relays sound like they are ok. i think the clicking means that your getting the electrical signals. anyone correct me if i'm wrong. for example, when i rewired my turn signals, i used 4 extra relays, the clicking sound of the blinker is now even louder. kinda annoying, not too bad. i just turn up the stereo to some Linkin Park. good luck.
Old 12-04-2001, 02:52 PM
yep, tried putting the old bulbs back... i really don't know where else to look.. the bulbs are ok.. the switch/relay seems to be working... unless the wires are burned somewhere along the line before melting the connectors ? ... i'm really hurting, man.....!!!
Old 12-04-2001, 09:33 PM
Mythos's Avatar
Mythos Mythos is offline
Send a message via AIM to Mythos
What was the wattage of your replacement bulbs? I have a feeling that they melted the harness. Also did you replce the nylon sleeve when you changed the bulbs? that is very important.
Old 12-04-2001, 10:48 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Mythos... I know what you're thinking(about the sleeve), but the fuse would've blown
dunno what it could be...
Old 12-05-2001, 02:17 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Check if you're getting current to the bulbs. Either put in new/surely working bulbs or use a volmeter. Are both lights not working?
And relay clicking does not necessarily mean it is working properly. It does, however, mean that the switch is OK.
As for telling if the harness is molten, just try to trace it from the lights to the relay and if there is this problem, *you will know it!*
Good luck, and hope this helps
Old 12-08-2001, 01:09 AM
i really appreciate all the advice from yall.
i did put some higher wattage bulbs on (6 months ago) and now finally paying the price for it.. i tried putting my old bulbs back on but no luck... btw.. how do i replace a bad relay... or worst.. how do tou replace the harness.. what is more difficult? please give me instructions for both.. i am desperate!
buddha
Old 12-08-2001, 02:59 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
The harness could be rather hard to replace depending on where you melted it.
The relay should be easy if what I'm thinking it is...just a fuse block in the pax side little black box. If you suspect it is one of those...you can just swap out one with another of the same color...they do the same thing.
-Brian Jones
I got a snake man
Old 12-08-2001, 05:29 PM
Mythos's Avatar
Buddha - what wattage bulbs were you using?
