Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 09-12-2003, 03:02 PM
Grounded Grounded is offline
Achieva PassLock problems
I own a 96 Achieva. It was working about as perfect as an Achieva can, until just out of the blue, the car wouldn't start. Rather, the car would start, but then immediately turn off. It was fine the day before. The "Security" light blinks, so i'm that the PassLock system is all screwy. Is there a way to fix this?
Old 09-17-2003, 11:14 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
You will need to pull the codes from the PCM and BCM to determine what the fault code is to help with diagnostics.
I would recommend that you go to your local GM dealer for this repair.
If I had to guess, I would lean towards the Passlock sensor in the lock housing.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-10-2003, 06:54 PM
tinytech69 tinytech69 is offline
Send a message via Yahoo to tinytech69
Re: Achieva PassLock problems
just bought an 96 achieva sl from used car lot read i manual about passlock and car lot didn't have the orig chip key how much do these run?
thanx
tinytech69
Old 05-05-2004, 04:30 PM
shotime8815 shotime8815 is offline
just changed my ignition switch on my 99 grand am and now security light stays on
Old 05-13-2004, 01:22 PM
jori jori is offline
My 96 just did the EXACT same thing; I spent approx $800 just on parts to have my passlock system fixed (I think they had to replace the ignition system, and do electrical work too) --- and that was at a shop where they didn't charge me labor (my dad's friend, thank goodness).
It's working great now, but I sure am wondering if it's worth it
Old 05-20-2004, 10:09 PM
vista461 vista461 is offline
I had that happen on my 96 Eighty Eight. The problem was one of the wires coming from the igniton lock(the part the key goes in),broke. I replaced it and everything was fine. It was around $60-70 for the part at the dealer with my discount. Labor was free since I did it myself If you have the tools it doesn't take REAL long.
Old 02-19-2005, 01:05 AM
Raymond4646 Raymond4646 is offline
I'm having a similar issue with my 96 achieva,
It was very cold out 15 degrees. I remote started the car and it did not start. I tried multiple times till the battery was near death. I tried leaving the key in the ignition for ten minutes to reset the passlock, didn't work. I tried to disconnect the battery, didn't work. I waited several hours and it started. I ran the car on the parkway and it died while going around a bend. All dash lights came on, interior lights came on then everything blacked out. The car then started back up while hesitating. The security light stayed on while driving. When the car was shutdown it started up but the RPM's immediately jumped to 3000 then slowly dropped... Please help. Thank you
1998 Oldsmobile Achieva--TRANSMISSION WON'T SHIFT... rheji Achieva 2 05-08-2012 11:42 AM
Passlock problem fixed for me surplusHP General Discussion 0 09-11-2010 05:14 AM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
96 Achieva Trans Problem JustRainMan Achieva 1 02-05-2006 09:38 AM
