Old 09-12-2003, 10:19 AM
David Anderson David Anderson is offline
99 problem with trailer lights
I have factory installed towing package with an aftermarket installed electronic trailer brake controller. Everything worked fine for three years, and then I blew the right turn signal trailer fuse. I replaced the fuse. Now when I connect trailer and lights the dash and radio blink with the turn signal. When I step on the brakes, everything goes dim and the signals don't blink. Also, five weeks ago I had to pull the 60-amp abs fuse since the pump motor would not stop running. I haven’t fixed this yet, and I know that Gavin Curtins has a fix. Could the disconnected abs be the problem or is there something else?
Old 09-13-2003, 09:39 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
First you need to find why the turn fuse blew...you may have a bulb that is shorted internally causing a feedback condition on the circuit.
Also if this problem occurred the same time you removed the 60amp ABS fuse, that fuse may have been a power source for other circuits (I dont have my schematics handy to check that fact)
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-15-2003, 11:46 AM
GMMerlin:
Thanks for the post. I will look into the bulb issue. The ABS failed and the 60-amp fuse was removed with no trailer attached.
Old 10-30-2003, 07:11 PM
JPyro24 JPyro24 is offline
i have a problem with my trailer lights on my 99' too, i keep blowing the right side trailer light fuse....it will work for awhile then it will blow.....brand new trailer.....no problems with the wiring harness...i dont' know what it could be...
