Old 09-08-2003, 11:07 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Which one should I do?????
Guys and girls, I need some input! I am unsure of what to do with my CRX. I have, right now, a ZC Tranny, a Zex cam for a Z6 head, a centerforce 2puck clutch, and a way to pick up a turbo setup (homemade, but complete...) for about $500. On the other hand, I sure would love to put in a b-series, but the allure of doing a turbo Z6 is really getting to me! What do you guys think? How much boost and how much horsepower can I realistically expect out of this setup with the Zex cam, without replacing or rebuilding again in a couple of months?? (I don't know any specs on the cam right off hand...) Or should I just go the safe route and get a B16 or B20? I'm really stuck with this!!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 09-09-2003, 12:07 AM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
that is a tuff one, how much r u willing to spend? cause the b16 will prob be a lil more then $500....but the z6 is vtec n a turbo on it would be nice, plus the cam, id go with that one
Old 09-10-2003, 01:58 PM
CRXtc CRXtc is offline
Banned
installing an N/A cam in a turbo car is a bad idea
Old 09-10-2003, 02:08 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
www.turbod16.com got a lot of useful information from tht site....check it out :thumbsup
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-11-2003, 10:59 AM
4GZChatch's Avatar
Why would it be a bad idea? All it would do is alter the timing and get more air in and more exhaust out, right? If the timing is too far advanced on the cam, I can always retard at the cam gear or at the distributor, right? Tell me if I'm wrong, I really don't want to Screw my project up from the git-go.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 09-11-2003, 11:19 AM
Banned
Re: Which one should I do?????
because high lift/long duration cams will hurt your performance, if you want cam(s) then look into a custom turbo grind cams, i know web cams makes them and i think crower does too.....you will explode your motor with those cam(s) and if you tune it to the point that it runs right with those cam(s) then you will be totally negating the affects the cam(s)
