Old 09-08-2003, 04:48 PM
mattlenderman mattlenderman is offline
Speaker INstallation (?)
does anyone know if there is a webpage where i can view Step-By-Step instructions on how to install front and rear speakers in a 92' accord? Thanks
Old 04-18-2004, 08:22 PM
cliffmo cliffmo is offline
Re: Speaker INstallation (?)
i need a wireing diagram for a saturn ls2, where can i get one?
Old 04-19-2004, 01:39 AM
skubydobdo skubydobdo is offline
for the accord, here goes.
For front door speakers......open the door and look at the interior handle. Pry the piece of plastic out of it and undo screw. Next, look below that where the tips of your fingers rest when you pull the door closed. Pry that off and undo screw. Look at the front part of the door and pull off any plastic covers you see and undo screws. Next, you have to pop out all the plastic clips that connect the door to the rest of the frame. Go around the whole door and pull the towards you. Once all is loose, carefully lift up and out and disconnect all wires. Repeat for other side.
For rear speakers, go into the trunk and undo the screws that hold the speaker covers in place. pull off cover inside car and then undo screws that hold speaker in place. Voila.
Old 04-19-2004, 12:00 PM
mjshort18 mjshort18 is offline
Re: Re: Speaker INstallation (?)
dude, you should not pull up old threads that don't even pertain to you or your car. if you need something you search for it and then if you do not find it you ask in the right section and by creating your own thread.
