Old 09-07-2003, 09:50 PM
mtdxx mtdxx is offline
94 civic cv boot
is replacing this a tough job? I think some hondas are difficult to remove the front hub, or something like that. This time I would like to replace the boot the correct way.
About 10000 miles ago, i replaced the other boot with a split boot. It is still holding up fine. I still may go this route. I am not sure. Anyone have any split boot stories?
Old 09-08-2003, 10:31 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
The only reason some Hondas are hard to remove the hub on is because some moron put lock-tight on it...or at least that happened to me once. But if the hub is not rusted, just get a good-size breaker bar, and you should be ok. Some times the ball joint isn't real easy to break loose though, but, it can be done using a hammer to knock it loose.
As for replacing the boot, once you have the axle out, replace both boots on the axle. You will need to take apart the joints (just pay attention on how it comes apart), get out the old grease, and put the new stuff in.
In my experience, split boots CAN throw grease all over even when put together properly. I'm not saying that they all do, just one I have used did that. Split boots aren't made to fit any particular car, or they will fit a broad range of cars, like a 90-2000 civic, which means that they aren't an exact fit, which might give you problems. IMO, do it right the first time and take out the axle.
Changing the driveaxle boots on a 944 S2 Dr944S2 924/944/968 0 10-08-2010 02:59 PM
Civic Hybrid Cars-- '06+ Civic 0 05-04-2009 07:30 AM
96 Civic HX o2 Sensor Replacement.... shvd98z24 '96-'00 Civic 3 03-30-2009 08:49 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
What size sub can fit comfortably in a civic boot? blitz_syd Car Audio 4 07-19-2003 11:48 AM
