Old 09-07-2003, 01:46 AM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
what could be wrong now?
lately my civic has a lot of starting problems... might be the california heat... 90+ degrees all day and a/c doesnt work!
i had a ecu code 16 earlier this week. i was told that the main relays were a common problem and replaced it with a new one. the old one smelled funny too . then i unplugged the battery and replugged it again. car is error free.
now after i drive for a while and try to turn on the car again the starter seems to struggle then start. my dad cleaned and rebuilt the starter about 2 months ago and it started fine until then. it might not be the starter. the battery is a few months old too. i don't think it's the ignitor thing in the dist. cap. it's also a few months old.
today i drove about 50 miles at night and it wasn't hot either. the temp gauge went up to about 75% when i was going up a 10% hill. its never done that before. i turned on the heater on to bring it down. it worked and i drove for a couple more miles. after i shut the car down and tried to restart it, nothing happened the engine didn't turn or anything. the main relay was clicking too so i think that wasnt the problem. there were no error codes from the ecu.
finally i was playing with the fuses checking to see of any were blown and i happened to pull the alternator relay fuse. while it was out i turned the key and the motor struggled without starting. the fuse wasn't blown. then i replaced it with a spare and tried to start again. it struggled then started finally what could be wrong now? my car has about 142k miles on it.. stock everything.
Old 09-07-2003, 05:10 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
well since you said yoru starter was struggling its one of 3 problems
1. your starter is no good
2. yoru battery is no good barely putting down enough volts to start the car
3. a ground is loose
4. something in the motor itself is causing alot of resistance, chekc your oil
as for your cooling problems, since when u put the heater on it worked, could be pretty much anythging, thermostat, waterpump, pressure lost somwhere like a leaking or loose hose, your radiator is bad, any one of those could cause overheating, make sure its not just low on water
Team Lonely Drivers
Old 09-07-2003, 06:27 PM
bionictony's Avatar
my dad did some tests and he says its the cylinoid on the starter. like it wasn't popping or something.. thanks for the input.. i'll check the hoses and waterpump.
Old 09-08-2003, 08:39 AM
ED7 Drifter ED7 Drifter is offline
Send a message via AIM to ED7 Drifter
can you guys help me? I am looking for the cooling radiator for my civic ed7 '90.
where can i find it, just online.I took a look at Takakaira.com but nothing...
The OEM costs 400 $...and it's plastic...
Old 09-08-2003, 09:15 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
check ebay or get a fluidyne rad, for 400 atleast they are made of aluminum.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-12-2003, 08:22 PM
tylertime tylertime is offline
if you find a local radiator shop they might redo your old one for 50-100 bucks cash warrantied rebuilt rads shouldn't be more than 200 at napa or wherever oem is always a rip-off
