Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-06-2003, 10:16 PM
Slap72 Slap72 is offline
2000 XLT door entry programming
Any tips on programming the keyless door entry? Just picked
up a 2000 XLT, but don't know the door entry code?
Thanks
Old 09-13-2003, 10:10 PM
chancedog chancedog is offline
You'll need a flashlight
Hey Slap72,
I just bought a 2000 Ford Explorer XLT too. The dealership didn't know the key code and the card with the code was not included with the owner's manual. Fortunately for me, there was a man there who knew where to look.
What you will need to do is get a flashlight and a if you have a small mirror, it would be helpful. I just happen to have one that I bought for doing PC repairs. When you open the back hatch of your Explorer you should have an access panel on the left that hold the jack and a crowbar. Open it and look inside towards the right. There are some wires connected to a white box. From what they told me, this is some type of computer, I guess for the security system. It won't be easy to see, but the factory code is written on the front of that box. I pulled the plastic panel out as much as I could and used the mirror and flashlight combo to read the number.
It worked for me. I hope it does for you as well!
Old 10-08-2003, 12:09 PM
AllanDuke AllanDuke is offline
Send a message via AIM to AllanDuke
Lightbulb Re: You'll need a flashlight
I was told that in order to get the codes for any 2000 or newer Ford Explorer, it had to be hooked up to the computer system in an mechanic. The Dealership that I took it to said that it would cost fifty dollars to do that.
But they could be wrong. People previoulsy told me that I could find the info by opening up the little compartment near the stearing wheel when the drivers door is open.
Original poster please let us know if the advice the other guy told you helped.
Old 10-11-2003, 09:10 PM
fas10secstang fas10secstang is offline
well i tried checking the computer in the back behind the panel and found the code. thanks BTW mine is a 1997
00GT bone stock (wifes car) , 89 LX ,KEITH CRAFT 306 (now residing in my nephews car)WITH STAGE 2 CANFIELDS, VICTOR JR, 750 DEMON CARB, NOS Big Shot 225hp,
Dynamic C-4 trans TCT converter 3000stall 10.52@126MPH. 352 w/Ed Curtis Specials coming soon!
Old 10-18-2003, 05:51 PM
silveroldie silveroldie is offline
Chancedog was right on. The code there worked for me and I have reprogrammed the door code.
1. Put in factory number (it always works).
2. Within 5 seconds enter 1
3. Enter 5 digit personal code with no more than 5 seconds between each entry
That does it.
Old 10-27-2003, 11:09 PM
BarryKlein BarryKlein is offline
Talking Re: 2000 XLT door entry programming
[quote=BarryKlein] Slap...... I found mine there tonight after coming here. I should have done it 2 hours earlier! I took the top bracket screw out ...and rotated the bracket down and back. Found a 5 number code on the paper sticker. Be carfull when you put the bracket back up. DON'T DROP THE SCREW!.
2000 Z71 Keyless Entry programming NVBigRed Silverado 15 08-30-2005 01:41 AM
2001 explorer sport door entry programming yorbay Explorer | Explorer Sport Trac 5 08-07-2005 07:55 PM
Keyless door entry programming?? beryce20 Explorer | Explorer Sport Trac 3 03-19-2005 01:30 PM
2000 Integra Keyless Entry Programming?? laurenlizpatton Integra 1 09-24-2004 09:58 PM
2000 Denali Keyless Entry Program greggolsen Yukon 3 02-24-2004 07:56 AM
