Old 09-06-2003, 07:20 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Question Anyone every tried a Sharpie Marker for Window Frames?
Hey has anyone ever tried using a Sharpie Marker for window frames? If anyone has how was the results? Was it kinda purplish? Cuz somtimes when you use a Sharpie its really dark purple kind of.
Old 09-06-2003, 07:22 PM
phatmitsu's Avatar
phatmitsu phatmitsu is offline
Send a message via AIM to phatmitsu
Thats what i use... You have to do it a few times but its black on the outside but it does have a slight purple tone on the inside.. I do about three coats.. Letting dry about 10min between coats.. Later Rick
Old 09-06-2003, 08:05 PM
=p
Re: Anyone every tried a Sharpie Marker for Window Frames?
Do u have any pics i can see?
Old 09-06-2003, 08:21 PM
phatmitsu's Avatar
Ummmm.. not really.. you can search for my integra i did a while back.. It had the windows done with a sharpie.. Later Rick S.
Old 09-06-2003, 08:26 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
It works good if you have a steady hand, if your shaky your SOL.
Old 09-06-2003, 09:04 PM
ZoomZoomMX-5's Avatar
Yeah, I tried it today on my RX-7 Spirit R that's now in the completed forum. Worked well, had to go over it a few times to make it black. Easier than masking/painting, or freehand painting w/a brush.
My Fotki Album
Old 09-07-2003, 12:16 AM
elvinKee elvinKee is offline
Send a message via ICQ to elvinKee
where to get the sharpie marker??do tamiya have it??
Old 09-07-2003, 12:32 AM
=p
U can get those almost anywhere,lol. Stationary Shop, Grocery Store ect.
Old 09-07-2003, 04:12 AM
ex-r's Avatar
ex-r ex-r is offline
I do. Here is a link to my thread. Scroll about half way down to see a picture. Click here.
Old 09-07-2003, 12:38 PM
Midnight Racer's Avatar
I agree 100%.I have used it and was happy with the results.
Old 09-07-2003, 01:19 PM
charlie_y charlie_y is offline
When you use the sharpie, do you colour the window on the inside or outside? Also, did you have to use any masking? How did you get it so perfect? And if you make a mistake, how can you remove the ink (ie. thinner)?
Thanks!!!!
Old 09-07-2003, 05:27 PM
blueboost's Avatar
blueboost blueboost is offline
I use one also and I am satisfied with the results, the S15 you see below was done with one. If you look closely I didn't do as good of a job as I should, which can be easily fixed with some rubbing alcohol. all and all, its the only way I would consider doing the rubber trim.
Thanks!!!!
I wouldn't recommend coloring in the window trim with it, we mean more specifically the rubber window trim on the model body's, not the actual clear window. the marker would be transparent if used on the window itself.
Old 09-07-2003, 06:35 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
I use the industrial permanent and laundry type markers. They tend to run a bit darker black than the regular Sharpie.
Also, for a nice crisp line. I'll BMF the area, use a marker to blacken out the frames, then trim the BMF like usual. I know, I know . . . BMF already make a Black Chrome foil. However, I find for some reason that the adhesion of the black foil sucks and you usually end up burnishing a lot of the black off anyway.
One last tip . . . The colored sharpies such a red, yellow and orange are good for detailing tail lights, side markers, etc. But again, I find that the cheaper brand and industrial type markers will leave less color fade and haze that the original sharpies leave.
Old 09-08-2003, 12:07 AM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
I tried but it didnt work very well.
Failure is only the opportunity to begin again more intelligently.
Old 09-08-2003, 10:27 AM
freakray freakray is offline
AF Modelrater
I tried it, it sucked, I won't do it again.
I couldn't get a satisfactory coverage with a Sharpie, fortunately I was trying it on a scrap clear part.
AF User Guidelines
2001 Park Ave, driver window works every other day tt23 Park Avenue 1 11-11-2009 03:45 PM
have anyone every build a Cyber formula's Race car? fairladyz_gt-r Car Modeling 0 11-20-2003 08:46 AM
Anyone every go to this site? bobbyd '88 - '91 Civic | CRX | Wagon | Shuttlee 15 08-22-2002 10:11 AM
