2000 Camry - No turn signals, no emergency flashers
2000 Camry LE - no turn signals, no emergency flashers. Fuse for emergency flasher checks OK. Is there a single relay for both turn signals and flashers? If so, where is it located?
Re: 2000 Camry - No turn signals, no emergency flashers
if you found out the solution, pls let me know, I am having the same problem
Solution
The relay found on the underside of the dash on the driver's side controls both turn signals and flashers. I replaced it (local auto parts store) and things are back to normal. Getting the old one out was quite an ordeal, what with the plastic housing that holds the relay detaching from the other dash relay holder pretty easily. I needed both hands, with a pair of pliers to hold the housing and a screwdriver as a lever to pry the old relay from its socket.
Thank you I bought the relay from dealer $50. I could not find it any where else. Yhanks
