Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-06-2003, 04:38 PM
TurboNutzz's Avatar
TurboNutzz TurboNutzz is offline
Fuel Management!
Hey, i just wanted to know what you guys are using out there for your fuel management. ANy suggestions would be helpful. I'm leaning torwards a v-afc 2 but still not sure, yes i have vtec so thats not a problem. thanks again.....
Old 09-06-2003, 04:56 PM
boosted331 boosted331 is offline
Re: Fuel Management!
For turbo/supercharger or nitrous please don't do the vafc hack. You'll make a lot more power with a good standalone.
<--- Hondata S200 with everything, including palmlogger. Great feature, lets you keep track of everything going on without dragging a laptop into the car all the time.
Old 09-06-2003, 05:39 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I am buying a standalone from Relentless Racing. Much better than the VAF-C. It isn't a bad piggyback, but I would rather have something with a little more control.
Old 09-06-2003, 05:41 PM
TurboNutzz's Avatar
Hondata is kind of on the expensive side though right? DOes benefits out weigh the costs difference?
Old 09-06-2003, 07:44 PM
Dude, a base S200 is 300 bucks. S200 with boost is 500 bucks, and it's about 5x better than the AFC hack. AFC only controls fuel and is a very crude way of adding fuel, and will have trouble idling bigger injectors. You also need to use a missing link so that your map sensor doesn't give you issues. Sure, for 500 bucks you can't datalog, or tune it yourself, but as long as you arn't constantly changing things you just need to get it tuned once, get a few gauges and run with it.
Old 09-07-2003, 05:25 AM
TurboNutzz's Avatar
yea, i did some more research and your right about the features and customization, but im in a 98 gsr so im gonna need a new ECU and the harness to go with it so im probably looking at around 1200 all said and done, its not exactly spare change when compared to a 300 buck vtec and air fuel controller, but then for the most part from what i've read, it is worth it so i guess i just have to save, up, thanks for the input people........
Fuel Management Domeskilla Cavalier 0 04-19-2003 06:29 PM
cobra fuel management cybercrx00 Mustang Talk 1 10-09-2002 08:41 PM
fuel management on p11 Sleepy Engine 3 05-22-2002 06:50 PM
stand alone fuel managment blk_GSR Integra 2 02-11-2002 08:22 PM
Fuel Management??? Phat_Si Forced Induction 4 01-24-2002 05:14 PM
