| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
How will you know how much HP you have without dyno? For instance, you have added the usual I/H/E setup, and you have or plan to have other mods?
Admin of PGamers Forum 1993 Honda Civic ESi (Sailor Mars) My wish list--I need help in this project: http://pikarod.fateback.com/car3.html |
true way to find out is dyno....you could get a gtech but the gtech readings will be lower than dyno because its factors in wind resistance, rolling resistane and all that other crappy stuff...put it this way....ive got 178whp on the dyno....on gtech it says 169hp....and thats after its been calibrated and the correct vehicle weight is set.
so whats wrong with a d15b2 again? |
Re: HP Without Dyno
Go to the drag strip and race your car as many times as you can. Then go to http://www.speedworldmotorplex.com/calc.htm and put in your info. I have found that the tarp speed method is more accurate, than the 1/4 mile method b/c of wheel spin etc. this will not be an exact hp but it will be fairly close just as close if not closer than the gtech.
Re: HP Without Dyno
hahahahaha i like that! BTW im hawaiian so broken english is what you get
Re: HP Without Dyno
previous post to my last, i was tryin to understand what you were saying. as ive only been on a dyno jet. i guess i need to read up on this type of dyno your talkin about....dyno jet is good just to let you know whp with no acting forces on the engine other than the base dyno......and the gtech as well as this dyno you are talking about would be for reall world whp....hmmmn but all n all all three methods IMO will give you a # that you can work with.
Yes, all three will give you an accurate relative number. :
Re: HP Without Dyno
They are using a 18% drivetrain loss. And you could always just use the bhp figure and then divide it by what ever the correct % of drive train loos your particular car has, if you happen to know it.
most honda trannies run a 15% drivetrain loss.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
