Old 09-06-2003, 10:44 AM
track_assassin track_assassin is offline
Question comp cam???
hi guys/gals this is my first time here...but anyways
the 411 : i just got a comp cam from zex and springs are required(got that too)
the queston: can anyone out there give me any info on how to install the cam and springs?
thanks a lot.
Old 09-06-2003, 09:34 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
OK first you will need to go to www.autozone.com and order a valve spring tool. Then you will need to buy a compression tester from any local auto parts store. Now take the valve cover off, unscrew all of the sparkplugs, then thread the hose that came with the compression tester into the hole that the sparkplug cam out of. Now you will have to connect the other end to a air compressor, this will put force on the vales from inside the cylinders to hold them up while you remove the valve springs. Ofcoarse ony do one cylinder at a time and take yor time and don't let the valve fall into the cylinder while the spring is off. Now replace the spring with the new one and repeat 16 times
You might want to also pick up a haynes manual for your car it will be helpful during the process and you will need the torque specs also
Edit: I forgot to say to move the hose that is connected to the aircompressor to the next cylinder when you are done with the first one, you can't just leave it in one cylinder to do all the springs lol
Old 09-07-2003, 08:07 AM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
You can just rent a compression tester and a valve spring compression tool.
1995 Honda Accord LX...all stocked out!
http://www.cardomain.com/member_page...page_id=356187
Old 09-07-2003, 05:28 PM
whtteg's Avatar
Re: comp cam???
Around here they don't have the spring compresor you have to buy it online here. So I don't knoe where he lives but it might be the same thing there as well. I dunno
Old 09-07-2003, 06:46 PM
thanks guys...i just went to buy a haynes book on my car, and looks like ur right. i'll tell u guys how much of a difference it makes after i put it in.
d16z6
intake
full catback
short shifter
15.5 q/t
comp cam any good? crabby760 Let's get Technical! 7 12-06-2004 09:49 AM
Comp Cams XE262AH 99 and up GT brentmcq Performance 6 10-31-2004 10:32 PM
Comps Cams croucher Camaro Discussions 0 09-27-2004 05:52 PM
Comp cam first impression jeef '88 - '91 Civic | CRX | Wagon | Shuttlee 6 08-26-2004 10:27 AM
Comp Cam Xtreme Energy Camshaft Journeyman General Discussion 0 02-20-2003 06:11 PM
