Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-06-2003, 12:13 AM
wolfsburg1999 wolfsburg1999 is offline
2000 camry le keyless programming
I have tried the put key in 2 times and open/close drivers door 2 times stuff and it doesn't work i have a keyless entry remote to add to the keyless only system and i can not get the programming to respond please help what is another way to program?
thanks
Old 09-23-2003, 01:31 PM
kathy saalfeld kathy saalfeld is offline
Re: 2000 camry le keyless programming
thanks
I have a 2000 Camry and each year has a different way to program remotes which can be obtained from any dealer. On my 2000 you have the driver's door open and then put the key in and immediately pull it out. Right away you click the door lock on the driver's side 5 times on and off. Close the door and again click the power lock 5 times on and off. Leave the door open and insert the key and pull it out two times. You should hear the power lock go up and down two times. The press the lock and unlock buttons simultaneously for more than one second. Then right away press either the lock or the unlock button for more than one second. That should take care of it.
Old 09-23-2003, 01:33 PM
Re: Re: 2000 camry le keyless programming
One clarification...when you put the key in the keylock two times on the third step, you turn the key to the on position and back off both times. Don't just put the key in and pull it out.
Old 11-05-2003, 02:00 PM
mitzi ware mitzi ware is offline
Re: Re: Re: 2000 camry le keyless programming
Does this procedure work for the 2000 toyota camry CE?
Old 11-05-2003, 08:38 PM
Jwhoov Jwhoov is offline
Hi Kathy;
I was able to program the new remote with your instructions and it worked but my other remote stopped working. It seems I can program
one or the other to work but not both at the same time...
The numbers on the back are identical... all of the numbers are.
Any clue? Does anyone else have a clue?
Regards;
Jim
Old 11-05-2003, 09:42 PM
Originally Posted by Jwhoov
Hi Kathy;
Regards;
Jim
I figured it out...... follow Kathy's instructions but if you have two
remotes, on the last step, select lock for remote #1 and Unlock for remote #2.....
I am a happy camper now.... I have two working remotes.....
Old 03-01-2004, 01:51 PM
Steve2000 Steve2000 is offline
thanks
Hi,
I couldn't get this to work either, but found these similar instructions which do work:
A nice fellow at doityourself.com gave me the following instructions for
programming keyless transmitters designed to work with my 2000 Camry.
Since I had a tough time finding someone to give me these and they
worked for my 2000, I thought I'd pass them along:
All doors unlocked, drivers door open
Insert key and remove(do not turn)
Lock and unlock doors with button on drivers door 5 times(1 sec
intervals)
Close drivers door, Open drivers door
Take key insert and turn to On position then to lock Twice, remove key
Locks should cycle lock to unlock by themselves if you completed the
sequence properly and it is equipped with keyless entry
In the next 10 secs or so complete the next step :
Take the remote and hold lock and unlock buttons at the same time for
about a sec and then press either lock or unlock for a sec. If the
locks cycle the programming was a success.
To add additional remotes, simply repeat the last step (hold both in, then press lock or unlock) on each one sequentially. Worked like a charm!!!
Old 05-03-2010, 10:00 PM
radji radji is offline
Tried all of these methods and I still cannot get the programming to respond. (Locks to cycle). Have gone through at least five different other methods and had no luck. Any help would be appreciated.
Old 05-09-2010, 05:55 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Super old thread - but are you sure you have the correct remote type and correct programming for your vehicle, as well as correct system type - FACTORY installed or DEALER/PORT installed?
There are 2 different remote types for the 00 Camry.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
96 Camry CSI Program Keyless Remote JeanC Camry/Camry Hybrid/Vista 1 07-15-2009 12:28 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
1997 camry keyless programing instructions aspen Camry/Camry Hybrid/Vista 6 12-14-2005 11:00 PM
98' Camry Keyless Programming Instructions prashantrk 4Runner/GX470 0 02-06-2005 10:01 AM
