Old 09-05-2003, 03:22 PM
crabby760 crabby760 is offline
Horsepower Question
Hey everyone i have a jdm b16a from a 94 delsol i was curious right now its all stock but i just order an injen cold air intake, 4-2-1 dc ceramic header and a apexi world sport exhuast system also i have 8.5 mm magnecor plug wires and new ngk platinum plugs does anyone have any idea what kinda horsepower number im looking to gain ??? as of now i know my motor puts out 170 hp and 115 lbs torque thats too motor not to the wheels... let me know what u think ill get to the motor now with these mods ???? thanks
Old 09-05-2003, 07:27 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you might be lucky to see 180hp at the engine and maybe 120lb/ft.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-06-2003, 01:30 AM
S13GTR S13GTR is offline
I would say about 10 hp's. If you want to pull some power out of the motor you will need to raise compression and do some headwork then you will gain hp in bigger numbers. (hint) the compression will do the most, you are at 10.4 right now and if you rais a full point you should gain about 20 hp or so.
Old 09-06-2003, 12:24 PM
seriously the b16a i would only gain 10 hp with aem cold air , dc header, full exahust, plugs and wires???? that's a pretty shitty gain?
Old 09-06-2003, 02:32 PM
adictionbass adictionbass is offline
i would say 15 at MOST. so yeah, 10-15 hp
Old 09-06-2003, 06:21 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Re: Horsepower Question
plugs and wires won't do jack for h/p numbers unless ur motor is already built. but on a i/h/e motor, u'll see less than 1 hp gain from it.
yes, on a b series motor, i/h/e usually gets u around 10-12 hp.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 09-06-2003, 07:21 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
You have added no power to your motor. period. Honda figures are based on an engine dyno, so when you add I/H/E your haven't added any part that makes more power, just parts that free up Hp that wasn't lost when it was rated before drive train and emissions loss. To make more than the rated Hp, you need to get more fuel/air into your combustion chambers and compress it into a smaller space. I have seen dynos for a B16A with I/H/E, ITR TB and IM, cams valvetrain, vafc, lightenfly,clutch touching just over 170. More often than not, they are in the 145-155 range with basic bolt ons..
Old 09-06-2003, 09:26 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Originally Posted by jcrx
..... I have seen dynos for a B16A with I/H/E, ITR TB and IM, cams valvetrain, vafc, lightenfly,clutch touching just over 170....
Sounds like someone needs to do better tunning. I have seen b16's with crower 63402 cams and 4-1 header, exhaust, CAI and vafc put down more than that.
Old 09-06-2003, 09:54 PM
crxlvr's Avatar
a member on this board has a stock b16 that dynoed at 145hp.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-07-2003, 01:31 AM
PreludeMOFO PreludeMOFO is offline
here i found this site to be particularily help full :
http://raceseek.com/honda_specs.htm
not sure if itll link or not so just type it in
hope it helps
Old 09-07-2003, 08:54 PM
track_assassin track_assassin is offline
thats true whtteg, a lot of power comes not from the parts alone but how well tuned it is. i head that tunning makes A LOT of difference.
d16z6
intake
full catback
short shifter
15.5 q/t
Old 09-07-2003, 10:38 PM
whtteg's Avatar
That is true tunning makes all the difference in the world. You cannot just put cams or any other power producing part on/in and not tune it, it will not be living up to it's potential.
track_assassin when you get your cam in you might want to gewt someone to tune your car, it will make a difference. There is a guy around here who will tune the car on a dyno with a wide band and program a chip for your ecu, or tune your hondata or safc/vafc. he charges like $100 hr but it usually only takes him 1hr or less so it is worth it int he long run
Horsepower Question?? jokers4141 Off-Topic 3 04-25-2004 10:03 AM
Is This Possible? Horsepower Question... Magik Si '88 - '91 Civic | CRX | Wagon | Shuttlee 4 04-24-2004 01:51 AM
Is This Possible??? Horsepower Question... Magik Si '88 - '91 Civic | CRX | Wagon | Shuttlee 0 04-24-2004 01:44 AM
horsepower questions GotboostB16 Engineering/ Technical 4 10-29-2003 08:35 AM
Horsepower question D15Bitch '88 - '91 Civic | CRX | Wagon | Shuttlee 13 05-06-2003 05:41 PM
