Old 09-05-2003, 08:23 AM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
cluch?........
ok which is better buying a stock clutch with a 12lbs flywheel or racing clutch but with stock flywheel.......i figure i dont have 200++ HP yet on my motor so why get a racing clutch why not get stock but buy light flywheel to use the HP that i have had b4 ...any inputs.....
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 09-05-2003, 09:53 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I'd go with the light flywheel, unless you have alot of hp, then there's no real reason to use a racing clutch, a honda clutch will work just fine. If you're going to take all of that apart, remember to change the $10 throw out bering while you're at it, or at least wipe the dust off of it and grease it again.
Old 09-05-2003, 01:46 PM
90hbvtec's Avatar
will the 90-91 integras clutch fit on the first gen b16a1 tranny..
tru sohc vtec......
Old 09-05-2003, 02:25 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
I think it will, not possitive though
KoRnSaQ
Old 09-05-2003, 03:12 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah u gotta use the 90-91 teg clutch on a first gen b16 tranny, the 92-93 i believe dont work
Team Lonely Drivers
shifting gears w/o the cluch poison_ivey Mustang Talk 13 02-24-2004 04:47 PM
My stock 10 YO cluch is bad, Any sugg. about aftermarket?? jeffseby Engineering/ Technical 4 06-30-2003 02:25 PM
??? Type R cluch and brakes??? typeR564 Integra 2 06-27-2003 03:16 PM
Dumpin' the cluch TrvlynAlec Engineering/ Technical 3 06-04-2002 08:05 AM
stiff cluch urasula Maintenance 6 08-30-2001 09:40 AM
