Old 09-05-2003, 12:39 AM
dougc dougc is offline
engine type question
So I Have the chance of picking up a HONDA VX motor for 200$ bucks. The vehicle i would be putting it in is a 90 Hatch. Let me know if i should pick up this motor.I don't know JAck SQWAT about honda motors?Thanks Doug
Old 09-05-2003, 12:46 AM
Skeme1's Avatar
Skeme1 Skeme1 is offline
vx motor specs
92 hp @ 5500
97 tq @ 4500
i would'nt bother putting that motor in your car
1990 DX D16Z6
Old 09-05-2003, 12:48 AM
would it be worth just to drive around.Not for performance? Does it have VTEC? I guess i should of put that in my first post HUH..-Doug
Old 09-05-2003, 01:39 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
If that is the only option you have to make the car run then it might be worth it. I think that the VX came with the Vtec-E motor, which was 3 stage vtec for better fuel economy. I may be wrong, but that is what I think. They get great gas mileage, but have no balls at all.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 09-05-2003, 01:43 AM
Talking
so it would be a great engine to get me through the winter then to the motor swap??
Old 09-05-2003, 01:56 AM
dirty91crx's Avatar
dirty91crx dirty91crx is offline
Send a message via AIM to dirty91crx
good all around stock motor....great on gas.....will get through through more than the winter.....may 10 winters? heh
so whats wrong with a d15b2 again?
Old 09-05-2003, 01:58 AM
Re: engine type question
HAHA thanks Guys for the info. THANKS -Doug
Old 09-05-2003, 02:09 AM
91civicDXdude's Avatar
the VX engine, a.k.a. D15Z1 does NOT have 3 stage VTEC. it doesnt even have any different cam profiles for VTEC.
VTEC-E is a system that runs in 12 valve mode under a set rpm, around 3000 or so, then after that point, it engages "VTEC", which is really just the 4th valve, making it run in normal 16 valve 1.5L SOHC mode.
